Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
Nothing comes out the expresso side. The steamer works okay, but when I turn the dial to the image of the cup, which should start the flow to the expresso filter, nothing happens except that eventually the steam starts coming out under the cap of the boiler. Nothing comes out the brewing head sieve. I took the sieve off to see if something was plugged up there, but it wasn't, and it seemed dry as a bone in there. Any ideas? I'm wondering if the mechanical switch has a problem. It was initially quite stiff. (tne machine hadn't been used since the '90s
  • seriousbus Oct 08, 2010
    Okay, but you're going to have to do a better job of describing the flow meter. What pump are you talking about. I'm not aware that there is one. Which tank are you talking about, the plastic reservoir for coffee water or the alloy tank for expresso water? And you're joking about neodimium, right?
  • seriousbus Oct 20, 2010
    Okay, but how do you get to the damn flow meter. It's inside a plastic housing and I see no indication of how to get to it.
  • 2,272 Answers
This indicates the problem of flow meter was not working. The flow meter is located between the water tank and the pump.
This is procedure how to test if flow meter is cause: Open coffee machine and pull out flow meter (do not disconnect it, just unscrew it from housing), prepare any magnet (neodimium magnet if possible), press the button to start making coffee. Coffee machine will start, then stop for a second, then start again. When it starts again put magnet close to flow meter's contacts and then move the magnet away and keep repeating that moves very fast. If coffee machine is working fine then you have to replace flow meter.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 08, 2010
  • raj somaiya
    raj somaiya Oct 08, 2010
    Flowmeter is a magnetic device with stops and starts the flow.
    here is the picture of how flowmeter looks like:--
    That is why i told you to check it with anexternal magnet to see if it gets commands as explained in my previous comment. And the water tank i mentioned above in my previous comment is the alloy tank of your unit.
Expresso is too large
Nancy, this setting is controlled by the settings menu. You reach that by right arrowing through the different beverages/menu selections until you select "Settings".
  • In settings, scroll to "program the amount"
  • place a cup under the spout
  • select the beverage you want to program, espresso in this case
  • select start
  • select okay when the amount of water has been used
  • the machine will remember this setting for future espressos
  • the same menu structure allows you to control the amount of coffee ground, as well as the amounts for other beverages
Mar 15, 2016 | Miele CVA 4066 Stainless Steel
My Krups 4000 Expresso machine while still heating up is not putting out any coffee(expresso)
I had the same problem. The issue was that the machine needed a clean to dissolve Calcium build up from the water. I used a commercial cleaner available at my local supermarket but have since used white vinegar and get just as good results. I just put about a cup of white vinegard in the water haopper and run the machine without the group attatched. I run the steamer wand and then put another cup through with the group attatched . I then rinse a few times with fresh bottled or distilled water.
Oct 07, 2009 | Krups XP 4000 Espresso Machine
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Krups XP2070 - expresso part - timing
It sounds like your flow meter is not working properly. Most likely it goes for about 5 seconds, stops and starts blinking with all the icons on. You can replace the flow meter and get it working again.
Dec 29, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Don't know how to work the steamer.
I have the same Conair Cuisine Ultra expresso maker as you; its an old one. Make sure the coffee grind is in the spoon/filter cup and as the water heats it will brew the expresso. Simply twist the the knob at the top of the silver steam valve stem will let out hot steam for you to frosh the milk.
Nov 24, 2008 | Coffee Makers & Espresso Machines
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Jul 14, 2008 | Coffee Makers & Espresso Machines
Lost my instructions.. How do I steam actual veggies?
  • The water level as long do not overflow is ok. Ensure water do touches the centre of the element.It's important to ensure there is sufficent water in the base of the steamer by visually viewing the transparent water level gauage.You can top up water on the either side handle.Turn the timer on if you think that the food will cook at 20 min or so.A receipes will help and tell you to set the exact min for cooking.
Regards
Alan
Feb 01, 2008 | Tefal 61621 Steam Cuisine 2-Cup Rice...
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
HELP FROM EXPRESSO NEWBE
What kind of machine do you have?
Sep 15, 2007 | Saeco 30511 Espresso Machine
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
220 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
