Question about Toshiba 19HLV87 19 in. LCD HDTV
"No programs are Shown".
I have Verizon Fios hooked up and the DVD player works and shows the picture..but when I go to watch TV it is just a blank screen that says "No prograns are shown".I have ordered the remote and manual..Do you think once I get the remote and program it..it will fix the problem or does this sound like a different problem?
Thanks for your time..
2 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: program not shown
try to see if the signal cable is connected, please consult the satellite provider.
melnavz
Posted on Nov 25, 2008
No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
Feb 15, 2010 | Westinghouse LTV-37w2 HDTV
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Can't record
id get some spliters and hook it up that way or call 888-553-1555 and up grade to a dvr where you can pause record and rewind live tv. or get the home media dvr where you can record 2 shows at one while watching a 3rd and record on the hmdvr and play that same show on up to 3 other tv's
Oct 29, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony Bravia
I have purchased KLV-40W400A Full HD but I am not satisfied with the picture quality. When the issue was raised sony is putting blame on Tata Sky and vise versa.
Kindly suggest.
Jun 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
HDMI crap out
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Feb 02, 2008 | Televison & Video
Toshiba 19HLV87 19 in. LCD HDTV Logo
232 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
