Question about Foxconn P4M9007MB-8RS2H Motherboard
Ram not detect but ram is istalled - Foxconn P4M9007MB-8RS2H Motherboard
  • Foxconn Master
  • 27,725 Answers
Make sure the largest ram is closest the CPU and that they have a secure seating
Posted on Oct 06, 2010
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
I have a ibm x3200 m3 server... i am trying to install software on it but when im about to start installation it beep once then hang then it restarts... i cannot istall software bcoz it does that... thnx
is it with that particular software or any software you try to install?
if its with any software you try to install try different ram or say you have two rams take one out aand try with one ram then switch slots and see,to me it seems more of a ram issue,if ram aint the issue then try same software of a different disc or download it scan it and try to run it,
May 07, 2011 | IBM System x3200 M3 7328 Server tower ...
Istall the ram but do not desplay ram is out of socket and than buzzer 3 bip I was install Ram to other mother board Ram is ok please solve the problem
It is the wrong speed ram for the other motherboard for instance 133 sdram, 100 sd ram, pc2700 ddr ram, pc3200 ddr ram etc. you will have to see what type of ram is acceptable in your new board.
Feb 15, 2010 | Intel D845GLLY Motherboard
I want to add 1Gig Ram to istalled 512 Mb of Ram,Can I do this? NEC VERSA M160. Memory type DDR 533 Mhz PC2-400 200 pinSODIMM
Yes, of course you can do this with your own. The first things you should do are they:
You need to buy 1gb RAM which same socket to your old 512mb RAM. Be sure that the said RAM are compatible to your motherboard.
Dec 02, 2009 | Computers & Internet
A7s333 motherboard with 3 dimm ram slots 2 x 1GB pc2700
That board type does not show on the ASUS web site. I think that your problem may be incompatibility of the RAM with the board specs. Placing faster RAM on the board will not make it go faster.
Oct 24, 2009 | ASUS A7S333 Motherboard
Will not boot
Dear friend.................Eject yor newly istalled RAM and clean it with a soft cloth and put it again in proper memory slot............
your pc will boot normally.................
if pc is not boot, complaint your RAM suplier.............
Apr 05, 2009 | Compaq Computers & Internet
Board problems....
you do have ram istalled? Pul the power cord remove the bios batt wait 3 min and try again. Make also sure your cpu is properly istalled. Check on board for faulty caps usualy swallen. Hope this helps have a nice day
Dec 08, 2008 | Matsonic MS8177C Motherboard
Can't istall xp
check your ram memory, the winxp must have at least 128mb ram memory and a videocard with at least 32mb. if you have these your pc will boot with no problem
Oct 23, 2007 | Intel Motherboard
Foxconn P4M9007MB-8RS2H Motherboard Logo
32 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
