Question about Dishwashers
Is there a quick fix to a flashing e3 on a Danby DDW497W?
  • Dishwashers Master
  • 3,247 Answers
Refer the user manual for your dishwasher. Error codes are given on page 7.
e3 means the heater is not working or the thermostat (which checks the water temperature) is faulty.
Not sure there is any quick fix other than to replace. If the heater is showing some reading on an ohm meter then it is likely the thermostat is faulty. In any case it will be easier and cheaper to replace the thermostat first.
You will need to call Danby service closest to you for advise on getting the parts or servicing it.
Please rate this solution to help fixya serve you better in future.
Posted on Oct 06, 2010
My danby countertop dishwasher ddw497w turns on, drains the water in the tub, refills and right before it usually fires up. click and nothing. just sits there with no fault code. any ideas before i sm
Hey Derrick,
According to the manual:
http://www.danby.com/cms/documents/pdfs/en/DDW497W_EFSOM.pdf
The most likely cause is the appliance not being leveled properly. Apart from that, I have found no useful information.
If you have a smart phone, try using one of the various, 'Surface Level' apps which will allow you to set your phone on the top of the appliance and then adjust the level until the bubble is centered in the crosshairs.
Hope this helps.
Oct 03, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
How do you fix the leaking window
We glued the inside window back in with some waterproof Goop and then caulked it to make it look neat. Hasn't leaked since.
Apr 08, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
What does an E3 code mean?
hello,
what this mean is an indication of a problem detected b the sensor
Some models of washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
thanks
Oct 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
I turned on my Danby countertop dishwasher without water! and now it does not work at all. Someone help me please, how can i fix it!!!
unless it ran for quite a while there should be no damage. plug it into the water, add a few cups of water to the water to fill the sump and prime the pump and turn it on it should work then.
Our danby at home shuts itself off when there is no water so I'm assuming thats what you are seeing.
Aug 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
Danby dishwasher E3 error
Same issue here so I just got off the phone with Danby. They said the E3 means the water is not hot enough when it goes into the machine. Now I dont know your guys situation but I let the water run hot until I cant touch it anymore, then I turn on the machine and plug it in. So it sounds like the heating mechanism is not working properly and does not heat the water to the appropriate temp to continue with the cycle. I will say that their support was really friendly and she informed me that since it was purchased less than a year ago it would be covered under the warranty. She gave me the number of a local repair shop. Lets just hope they dont tell me nothing is wrong with it because my water temp is fine. I will let ya guys know. Here is the number for Danby that I called. General office: 419-425-5052. Good Luck!
Jul 21, 2008 | Dishwashers
E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Jun 11, 2008 | Danby DDW496W Free-Standing Dishwasher
Dishwashers Logo
363 people viewed this question
Top Dishwashers Experts
