The thermostat will not cool the house its 83 deegrees its hot its a robertshaw 9500 I need help please what do I do to fix this cheap ****.
  • 24 Answers
Your thermostat is probaly not the problem. Is the outdoor unit running?
Posted on Oct 07, 2010
How to fix robertshaw thermostat display after changing batteries?
How To Replace Thermostat Batteries - YouTube
? 1:46
www.youtube.com/watch?v=QFd5jGL6vpM
May 10, 2012 - Uploaded by KungFuMaintenance Kung Fu Maintenance demonstrates how to change out thebatteries on most digital air conditioner and heater ..
Sep 19, 2015 | Robertshaw Thermostat Accessories 9010-1...
Won't let me put in seperate set points for cooling and heating. I reset to fac setting, it used to let me have 2 settings.
www.ask.com/mfg.name/make/model#/
/setup_procedures/
/program_instuctions/
/optional_settings/
/discription-of-settings/
/additional_settings/
by reviewing your information that you provided you state that the unit in a non-programmable unit, that means you have to use the pre-set options, they cannot be changed, only someone that is a programmer, if you want a programmable unit than you should buy one, because every time something goes wrong you have to re program the unit. good luck
Sep 17, 2015 | Robertshaw 9500 Digital Non-Programmable...
I have a robertshaw thermostat not sure which brand per say. All I know is that's its a little older by how it looks. Usually does the job great but the past to days it'll cool the house but the...
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Sep 13, 2012 | Cars & Trucks
My heat ( only blows cold air) won't work and my car seems like it's going to overheat. What could this be?
First, start by replacing the thermostat. It's located under the coolant filler cap / thermostat housing on a 2.4L dohc engine block on the upper left (passenger side)of the engine. We just replaced one in ours, but when we took the thermostat housing off, we discovered that the thermostat had broken/exploded, and that the lower thermostat spring and retainer were probably stuck inside the engine cooling galleries. We ran the car without replacing the thermostat, but it did not improve. The engine was still getting hot, and the heater blower still wasn't blowing hot air. We're going to try to replace the thermostat with the correct one (parts place gave us the wrong one and it didn't fit at all...), bleed the air out of the system again and see if there's some kind of link to there having to be a thermostat in the system. If that doesn't fix it, I'll have to look at the water pump to see if it's actually moving the water or not. If the water pump isn't functioning, the water isn't getting moved from the hot block to the radiator (where it's cooled through the radiator and goes back into the suction side of the water pump). If the pump is fine, and the new thermostat doesn't fix the problem, we'll have to investigate the possibility that the thermostat parts that got into the water galleries is somehow restricting the cooled water flow back into the engine, and that will be an expensive fix, I presume. Like all other cooling system problems though, start with replacing the thermostat. It's fast, cheap and will let you know where to look next if that doesn't fix it, but that problem is usually only a thermostat issue.
Feb 09, 2011 | 2002 Chrysler Sebring
My Isuzu Rodeo begins to run hot after driving for about 5 minutes .. Then it cools off and stays about normal .. What could this be ??
The thermostat is sticking closed. You need to replace your thermostat. Very easy and cheap fix. Follow the top radiator hose to the engine. There is a housing on the end of the radiator hose. Take the housing off and you will find the thermostat.
Please RATE this if it help you. Check one of the four THUMBS UPS! Thanks!
Sep 21, 2010 | 1997 Isuzu Rodeo
Heating & Cooling Logo
369 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
