Question about Samsung Heating & Cooling
I have a split system a/c that the head unit will not respond to the remote. If I turn off the power and restart and I manualy push the button it comes on and blows cool air and then shuts off but I can't get the remote to do anything. Batteries are good and the remote works on my the other unit. I think I need to replace something in the head unit cause it acts like it doesn't acknoweldge the signal from the remote.
  • 236 Answers
Replace receiver board or if you have a spare unit try to transfer the receiver board to the defective one and test the remote to confirm the unit problem.
Posted on May 30, 2008
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
DAIKIN Aircon Multi Unit - One head unit not working, others are fine. No lights or response
Check for power at unit . If there is power to unit check for blown fuse on circuit board or bad board .
Nov 11, 2014 | Heating & Cooling
Split system air con LG model LST 2434C-2 unit won't turn on, remote is working but unit won't respond, turned on at wall.
Check there will be red icon when power is on,before switch on by emote. If no red light, there is no power goes into indoor unit. Check. If red light is there and no response with remote, communication error between remote and PCB in indoor. Try with other same type remote. If yes, replace battery or replace your remote. If no, receiving sensor in PCB problem. Repair or replace it.
Jan 13, 2011 | LG Heating & Cooling
Have model ASTB24LDC/AOTS24LDC Inverter Fujitsu split system. As of Thursday 11th Nov, unit stopped working. Won't respond with remote. An electrician came to test it this morning, says there is power to...
I have same problem like yours to my newlyinstalled Fujitsu multi-split system (the first time use since system installed1 week ago). I rang the electrician whodid the installation; he said it must be the units themselves nothing to dowith electricity. Okay, then I rang Fujitsu and their local service agent. Theysuggested me to switch off C/B for an hour to reset the units. I followed theinstruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired tothe outdoor unit). So I used a multi-meter to test the power terminals of indoorunits (Danger! If you have no idea about this, don't even try! ): it seemed nopower supply even C/B is on. I turned to the isolator which next to the outdoorunit. The isolator was making arcing noise when I switched it on and off. Theindoor units suddenly turned on for few minutes then died again. So I figuredout the problem is that crooked isolator. I called the unhappy electricianto replace the isolator. End story....
I hope my experience will give a littlehelp to you...
Nov 13, 2010 | Fujitsu 24C1 Air Conditioner
The air conditioner doesnt respond to the remote
this units ahve a reset boton on the roght side of the unit open the lid like if you was gonna change filters a small boton should be on the right side of the unit push it and if your unit turns on then you need to get a new remote if it doesn't then is your PC board
Jun 02, 2010 | Continental Electric CE-AC7581 Ductless...
Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
May 08, 2009 | Sanyo 18KS52 Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Heating & Cooling Logo
161 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
