Question about Braun Syncro 7680 Electric Shaver
Top housing for the charging stand for a Braun Syncro 7680 Electric Shaver
When the portion on top of the charging stand is pushed down, it springs up and won't stay down. It appears to me that either a spring of some sort has to be replaced or the complete top housing has to be replaced.Where can I buy either the spring ( or other part/s that are necessary to remedy this) or the top housing for the base unit?
  • 3 Answers
I just experienced the same problem and came up with this solution. Use a spring clamp to keep the top of the charging stand in place. It works like a charm.
Posted on Sep 14, 2008
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at See links below
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
I have a braun 7680. after I was done shaving it would not shut off, It was stuck in the on position and would not slide back to the off position. what is need for repairs. is too messy to full around with switch repair as too many plastic parts etc.
ordered the following from Shaveroutlet for $25 and replace the top assembly....takes less then 10minutes.
Jan 13, 2011 | Braun Syncro 7526 Electric Shaver
Where to get and how to replace the shaver switch on 7680?
The switch is part of the outer case and can be found at See link below
To replace, you will need to gently pry off the cap that surrounds the cord hle on the bottom. Once removed, the side grips will pull away easily revealing 4 screws on the back. Remove screws to take the bask of case off and then lift out the 'guts'. Reassemble in reverse order
Sep 30, 2010 | Braun Syncro 7680 Electric Shaver
I cannot click the top on when i try to charge it ....
The latch on the 'arm' of the clean and charging base is broken. You can either change out the top portion of the clean/charge base or replace the whole thing if you don't thisnk you can do the repair.
Both itemsare available at See links below. Basic instructions for installing the top part are included on the item page
Sep 26, 2010 | Braun Syncro 7570 Electric Shaver
I have lost my instruction and cleaning manual for Braun electric shaver #7680 and need to find replacement.
Here are the instructions for a #7680 Shaver.
Apr 26, 2009 | Braun Syncro 7680 Electric Shaver
Braun Syncro 7680
the red light tells you it is cleaning, a green flashing light tells you it's charging
Jul 28, 2008 | Braun Syncro 7680 Electric Shaver
Charging stand
I just had the same problem, where the top of the charger would not stay down. I tried a spring clamp to keep it in place, and that works like a charm! Try it!
Aug 19, 2007 | Braun Syncro 7680 Electric Shaver
Braun Syncro 7680 Electric Shaver Logo
258 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
