Question about Kitchen Ranges
Model # LGGF3042KF control panel failure Last winter I bought a Frigidaire Stove from Lowe's. Within a week, the control panel went out so all I could use was the burners. The control panel was back ordered and I did not get it repaired until Mid January, ruining our holidays. It is now October of the following year and it just went out again today, Help! Model # LGGF3042KF control panel failure
philbran
  • 242 Answers
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
  • 172 Answers
SOURCE: GE Spectra stove, oven won't light
Hi ewood,
You can look up your ge owners manual at ge.com . If the oven has stopped working chances are you have a bad ignitor. the part number is WB2X9154 . The part is $69.99 and I have this item in stock. Shipping will be $6.50 in the continental US>
I hope this will FixYa. If you have more questions please let me know. I can tell you how to remove the old ignitor if needed.
Anderson Appliance
Mike Anderson (Owner)
(865)945-3808
Posted on Sep 30, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
SOURCE: Front burner won't shut off. Have to close at breaker.
For $9.99 I will be glad to share the solution.
Posted on Jun 21, 2009
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
We bought a Frigidaire freestanding gas range model# LGGF3042KF, but didn't realize till now that it was preset for natural gas. We need a conversion kit to change to propane and I have no idea which one...
HI. I have located a conversion kit for your model. Simply click on the link provided below to access the purchase page.
CLICK HERE(Part Number GRLP3)
Installation instructions will be included with the shipment, to assist with the installation.
NOTE(A quailified LP technician is required to make the conversion.)
Nov 05, 2009 | Frigidaire PLGS389EC Stainless Steel Gas...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Kitchen Ranges Logo
203 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
