Question about Clarion RDX655Dz
Only volume and function button works, nothing else
Only the volume control works, and the function button works, all the station buttons are not working and neither is any other button
cant change station or track if a CD is in
please help
thanks
I opened up the Faceplate to see if there was something wrong, turns out there was coffee and chocolate keeping one of the buttons stuck on, its all cleaned out now and works great
Posted on May 29, 2008
My stereo keeps turning off when I listen to a station 101.5 in New Jersey
The only thing that can be is that you have set a timer "sleep" function for that station. I have looked at the manual and it states you can programme a sleep setting for a radio station.
The instructions are on page 12. But I have extracted them below:
1 Press the ON/STAND-BY button to turn the power on.
2 Press and hold the CLOCK/TIMER button.
3 Within 10 seconds, press the or button
to select "ONCE" or "DAILY", and press the MEMORY
button. Set the clock to the correct time if "ONCE" or
"DAILY" does not appear.
4 Within 10 seconds, press the or button to select
"ONCE SET" or "DAILY SET", and press the MEMORY
button.
5 To adjust the hour, press the or button and then
press the MEMORY button.
6 To adjust the minutes, press the or button and
then press the MEMORY button.
7 Set the time to fi nish as in steps 5 and 6 above.
8 To select the timer playback source (CD, TUNER, USB,
iPhone/iPod, TAPE or AUDIO IN), press the or
button. Press the MEMORY button.
When you select the tuner, select a station by pressing
the or button, and then press the MEMORY
button. If a station has not been programmed, "NO
PRESET" will be displayed and timer setting will be
canceled.
9 Adjust the volume using the VOLUME control, and then
press the MEMORY button. Do not turn the volume up
too high.
10 Press the ON/STAND-BY button to enter the power
stand-by mode. The "TIMER" indicator lights up and
the unit is ready for timer playback.
11 When the preset time is reached, playback will start.
The volume will increase gradually until it reaches the
preset volume. The "?" or "DAILY" indicator will blink
during timer playback.
12 When the timer end time is reached, the system will
enter the power stand-by mode automatically.
Once timer:
The timer will be canceled.
Daily timer:
The timer operates at the same time every day. It
will continue until the daily timer setting is canceled.
Cancel the daily timer when it is not in use.
Jan 06, 2016 | Sharp CD-DH950 5-Disc Compact Stereo...
Guys, I have a CDX GT610, the issue is that is
hi marco, the problem seems with the switches on the face. make sure that ALL switches have a "click" sound when pressed down. if not then that switch needs to be replaced. faulty switches can cause the face functions to work erratically. to try another route use your unit with the wireless remote control to check if all functions work well. cheers.
Sep 06, 2013 | Sony CDX-GT610Ui CD Player
Sony cdx-gt610ui buttons won't work
Guys,
I have a CDX GT610, the issue is that is not possible to change stations, even if I try with the push buttons to record the stations, it remains on the same station (number 3 in my case), besides the volume gets high if I want increase the volume, any suggestion about it??? please let me know
Best Regards,
Marco Hernandez
Feb 26, 2013 | Sony CDX-M630 CD Player
I have a new vizio 37", just got it, On some stations the volume is so low, I can't hear it. I have cable tv, the volume on the cable box is way up where it says sterio;when the volume is on 100 % it still...
On remote hit tv button hold set up until it flashes twice. Hit 11758 it will flash 4 times hit set up to lock. Now hit tv button and the volume should work on set.. Hope that works
Jan 30, 2010 | Vizio L37 Television
I have a new ESTR 200 that has been in a closet for a couple of years. Very little seems to function well. The presets will not hold if I turn the system off or if I turn to another function. Record...
I assume we're talking about the Element ESTR200...
A turntable will not work with this receiver unless the TT is already preamplified. No Phono Preamp in this unit.
Presets:
From the manual...
Store a station
1. Press the FM/AM button on the front panel (or
the AM/FM button on the remote).
2. Select the station you want to store in memory
by the methods described above.
3. Press the MEMORY button on the remote
While "MEMORY" is glittering, press number
buttons on the remote for the station.
If the Memory indicator on the display turns off before you preset the station selection, Press Memory again.
Manual preset
1. Select the band wave by pressing FM/AM
repeat.
2. Turn to a radio station(see "Manual tuning" on
page 8 in details).
3. Select a group (A- D) of preset stations. This
group will be displayed on the front panel.
For example: "A".
4. Press MEMORY on the remote control.
"MEMORY"will appear on the display.
5. While the word "MEM" appears, input your desired preset number (1-8 ) by using the numeric keys on the remote control to store the radio station. For example this number is "1", the station is stored as "A1".
NOTE:
A new setting can cover the former one.
This memory is kept before next reset.
Retrieving preset stations
1. Press FM/AM button on the front panel or the
remote control to select tuner mode.
2. Press A/B/C/D button on the front panel or the
remote control to select the group of preset stations that you require.
3. Press the numeric keys on the remote control to select the number of preset station that you require. Station selected is displayed on the front panel.
4. By the same way, you can select other stored
stations.
The remote control does not operate the unit.
-Another function is selected on the remote.
Press the correct function button.
-No batteries installed. Install the batteries before
using the remote.
Be sure "+" and "-" marks of each battery match the symbol on the inside of the remote battery compartment.
-The batteries are exhausted. Replace all batteries.
-The remote is not pointed at the remote control sensor on the main unit or there is an obstacle between the remote and the main unit.
-The remote control is too far away from the main
unit, move closer.
Dec 05, 2009 | Audio Players & Recorders
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing...
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Mar 02, 2009 | Logitech Harmony 880 Universal Remote...
Pioneer DEH 225 car radio instructio booklet
Actually, there a re a bunch of hits when you Google it.
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
  • With the ignition on and radio OFF,
  • Press and hold the MULTI-CONTROL button for 2 seconds
  • Rotate MULTI-CONTROL button until display reads CLOCK.
  • Push MULTI-CONTROL button up or down to adjust hour and minutes.
  • Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
  • With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
  • (If you do not have a function button, use the AUDIO button instead).
  • Press the FUNCTION button again until the clock shows on the display.
  • Press the UP and DOWN buttons to adjust the hours.
  • Press the LEFT and RIGHT arrows to move to the minutes.
  • Press the UP and DOWN to adjust the minutes.
    When you've completed all the steps, just press the SOURCE button to exit
If your car CD player is 1999 or older:
  • While holding down the CLOCK button, press the number preset button to set the hour.
  • While holding down the CLOCK button, press the number 2 preset button to set the minutes.
  • Pressing the respective buttons consecutively or continuously will advance the hour and minute.
For further assistance please consult your user manual.
Here are some other answers from around the web:
Hold down the source button till the unit switches off. Press thefunction button until it says clock. Use the tuner/volume controls tochange the time. Left/right switches between hour and minute. Up/downchanges the actual numbers.The website I'm including has all the old manuals on it if this doesnot work for you. Problem is, you may not know your model # so willhave to click through the links till you see a pic of one that lookslike yours. Hope this helps. I'm stoked that my clock is finally right!
turn the radio OFF with the car ON
then its easy to set the clock.
Most folks try to figure it out with the radio on
and it cant be done with the radio on,
Turn it off. Hold down "func" or "function" until something happens.
Then press the arrow keys still something else happens. When you're done, press "func" or "function" till nothing happens. Turn it on.
Dec 03, 2007 | Pioneer DEH-225 CD Changer
Car Audio & Video Logo
316 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
