Question about Philips Magnavox 27MS343S 27" TV
Philips TV 53c DCV type 29PT2204/94R No IL300744 005753 \r\nhavind problem with TV, It shows on screen display as follows:- 04664 LO 4AN21.2 ERR 11 10 19 15 0 OP 160 149 128 032. KINDLY ADVISE PLEASE. THANKS KK
2 Suggested Answers
gopakumarg43
  • 74251 Answers
SOURCE: philips tv crt type i forgot reading the model(turns on with display on screen then turns off in seconds)
The main chroma IC should be suspected. Without knowing the exact model number, it is difficult to point put the number to this IC If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 04, 2014
Testimonial: "ok sir.. i can provide you now the model no.of my phillips 21' crt tv ..its 21PT1323/71R...Your suspecting the same with me..I Have done troubleshooting the SMPS AND vertical section but it's good..these tv has chroma ic no. TDA9580/NI/311101..is there any techniques on how to fix with this ic or a replacement?where can i buy those ic?i'M FROM CEBU,PHILIPPINES.."
My Philips 21 rf vardaan TV there is a problem my TV Is showing MONO option on screen on the right side and AV1 on left side and the screen is blinking, how can I eliminate this problem
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 26, 2016 | Philips Televison & Video
Nesecito un c?digo para mi DVD Philips para q lo pueda encender con un control de dish
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 10, 2015 | Philips Televison & Video
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Activating HD mode
You do not activate or set the TV resolution at the TV, the signal feeding the TV has to be hi-def for the TV to show HI-DEF. TV will show what is being fed with, lo-def in = lo-def display.
Dec 09, 2009 | Sansui HDLCD1908 19 in. LCD TV
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
Jan 29, 2009 | Televison & Video
Problem with televisor phillips 27f8007583 chassis
Philips 27f8007583 how to reset auto programming
Dec 29, 2008 | Philips 24PT6341 24" TV
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
