Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Brought a new monda vege spray sink mixer for kitchen.Not sure how to connect the mixer hoses together.No picture instruction were provided which makes it hard to install.
  • Anonymous Mar 24, 2014
    monda basin mixer
    Sergeant:
  • 268 Answers
It does, hot connection goes one side and cold connection goes on other. If you get it wrong then just swap em. It intalls better then you one you took off. I believe it just requires 1 nut to go on bult.I replaced mine in 3 minutes.
Posted on Oct 07, 2010
  • weezlebub May 01, 2011
    The monda vege mixer is a little more complex than the standard mix-tap, at the base of the mixer you have 3 inlet holes, H, C & an unmarked one in the centre, H for Hot, C for Cold, unnamed for the long tube thinggy, the copper two-piece thing goes on the end of the long metal tube thinggy, with the head unit hose attached to the bottom of that ... that seems to be the most complex part of it ... although, i've got mine installed and semi-working (i have no hot, but hot water comes out when in the cold on position) ...
How do I replace the sprayhead?
replace the sprayhead Dragon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kitchen Sink Faucets How to Remove the Spray Head From Sink
How to Repair Single Handle Kitchen Faucet With Spray Hose Kitchen Plumbing
Pull Out Kitchen Faucet Sprayhead Replacement
Replacing the Kitchen Sink Spray Nozzle
May 25, 2016 | Plumbing
Grohe 46 092 000 Pull-Out Spray Replacement Hose, StarLight Chrome I have the part are there any videos that show how to replace it
How to Replace a Kitchen Sink Spray Hose - YouTube
? 1:43
www.youtube.com/watch?v=oIt4ofmCEAk
Oct 4, 2012 - Uploaded by About.com Learn how to safely and correctly replace a kitchen sink sprayhose. ... How to Connect a Sink Sprayer : Home Sweet Home Repair - Duration: ...
Sep 27, 2015 | Grohe Home
Rowenta 1500 garmet steamer no longer makes steam
Someone else had this fix and it worked for me: (yay!)
*Remove water tank and collapse the hanger bar.
*Remove two screws at base of hose and work the hose off. It will come out.
*Unplug unit and hold over your kitchen sink with the hose inlet pointing into the sink.
* use your kitchen sink sprayer to forcefully spray water into this hole and it will come back out again releasing the gunk that has been stopping up the unit.
* for good measure, I also used the sink sprayer to flush out the hose.
Put everything back together. And make sure it is dry before you plug it in.
VOILA!!! WORKS GOOD AS NEW. HAPPINESS!
Jan 10, 2014 | Conair Gs4 Iron
There is a leak where the spray arm connects to the water faucet under the sink. The connection is a snap connection rather than a screw on type.
With this type of faucet when you push the 2 pieces together there should be a small rubber O ring, if this is not in the correct position there won't be a proper seal. If you have some vasalien rub it on the O ring and it should help it fit better, it also should click when you push it together.
Mar 16, 2013 | Moen Monticello Single-Handle Kitchen...
How to remove the cartridge from a monda sink mixer tap?
first shut off the water under the sink:) next put the stoppers in the sink so you dont drop anything in the drain:) then examine the handle closely and you will find a plastic/rubber "knob" like a wood dowel which is hiding the bolt we need to access to remove the handle. carefully remove it (it may be gone already depending on how old your faucet is and it will be pretty small) most likely you will need an "allan" key to remove it. now there is just the threaded ring which holds the cartridge in place. now its possible that grohe makes a tool designed to remove this ring. i am actually not familiar w/this model but you do not need it. you can use a pair of channel locks w/a dish towel and a lite touch to loosen the ring (ritey titey lefty loosey:) now the cartridge should come rite out but it may take a little coercion. just let me know if you need anything else and good luck:)
Jul 27, 2011 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Is there any reason why the hot and cold can't be changed over in a mixer tap? Our model is a Monda. The instructions are to connect hot and cold to specific sides of the tap, but this doesn't suit our...
The only way is to get a new faucet. This one was designed for separate hook ups. Any plumbing supply house can get you what you want. Its an easy install, but will have to be a new unit.
Dec 25, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I need to change pullout sprayer hose how to do that
if it is a quick connect hose squeeze the push in clip together and pull it out and pull hose off. then do that in reverse.
Dec 03, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Can't get the replacement hose through kitchen faucet
you will need to undo the tap from the sink pull the tap up a little and feed the hose through the hole and connect it to the tap then re fix the tap to the sink most pull out taps are painfull to change the hoses
Jul 13, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
1,296 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
