Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC AV-56WP74 I had my tv looked at it and the repairman said it was my blue picture tube. I have the part but it is not new and they wont put it in. Can you tell me hoe to change the tube?
  • stankeynutts Jun 07, 2008
    red and green seem to be working great. the blue is dark and dim
  • JVC Master
  • 8,617 Answers
You would need the service manual in order to change the picture tube properly as there are dangerous voltages stored inside the tube also the tube would have to be set up properly as well. You can get the service manual for your model at the following link. They will email it too you right after purchase. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 28, 2008
I have a jvc av-56wp74 56 in rear projection tv it has a lil purplehalf moon on upper left corner about 1 ft wide and 2 inches down and the tpo lefthand corner is lil blurry the rest of tv is fine any help...
Well David, it sounds like you need to unplug and open back and try to stick your head up in set and look down into CRT's tubes, you may have phopser damage on one of the tubes, you will need to turn on to see it just be careful not to touch anything electrical
Feb 02, 2011 | JVC AV-56WP74 56" Rear Projection...
My tv is a jvc av-56wp74 it looks like 3Dwithout the glasses the colors dont line up
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | JVC AV-56WP74 56" Rear Projection...
There is no red in picture on model number av56wp74 jvc rear projection tv what's wrong with it?
Ur CRT red gun is dead.Must hire the repairman for this job.It require part is hard to find,and alot of work and electronics skills to do this job.
Mar 17, 2010 | JVC AV-56WP74 56" Rear Projection...
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
Blue screen
It sounds like the cooling fluid in your picture tube(s) has become dicolored - this can be seen if you dismantel the unit and view the picture tubes directly - they will appear foggy - replacing the fluid can be a time consumming and expencive task.
Sep 18, 2009 | JVC AV-56WP74 56" Rear Projection...
HOW DOES THE FLYBACK AND FUSE LOOK ON THE AV-56WP74
Hi
the flyback is a high voltage step up transformer that light up the CRT tube. usually this is color black or sometimes Grey with have anode wire attach in the picture tube. the fuse are so many types of fuse,. but in this model the fuse is like crystalin glass tube with metal at both ends..
Thanks!
Jul 08, 2009 | JVC AV-56WP74 56" Rear Projection...
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
TV Has no pitcher
you could have a shorted tube Green disconnect CRT board from green tube if set stays on tube is shorted also check video ic on crt board.
Dec 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Hardly any Blue Color in the picture. the blue tube is projecting darker and dimmer.
You need a Blue picture tube CRT you can get one for your JVC at the following link for a real decent price and they provide free shipping. Heres the link.
Jun 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Blue Shadow on my AV-56WP74 56 in JVC
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 04, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
