Question about Hampton Bay B552ODWH Gazebo Plus Ceiling Fan
I bought 3 of these B552ODWH fans about 11 months ago and the light bowl fixtures are cracking and falling off. they seen to be cracking from light heat i guess. not very durable. can i get them replaced?
  • 377 Answers
You can find replacement parts through this URL:
http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fans.php
Are you sure you are using the recommended wattage for the bulbs?
If this solution helps you, I would appreciate a Thumbs Up rating.
Be well, Paul
Posted on Oct 06, 2010
My 01 katana been sitting up it will crank idle for a few than die out and wont crank until it sit awhile
Hi, Kevin and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bike dies when you give it throttle
Suzuki GSX600F Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Oct 04, 2016 | Suzuki GSX 600 F (Katana Motorcycles
Hello. I need help with my fan, please. I have hampton bay ac-527 nn sku# 360-424 . Trying To remove light To replace burned out bulb light but having trouble removing. HELP ME PLEASE. Mike
You got me wondering about a fan I have with an enclosed bowl-like light fixture (I don't know how closely this resembles your model, but bulb access is not immediately obvious on it either). I looked on top of the light section and found a #2 Phillips screw on the top plate of the light fixture near the rim. It seems likely that loosening or removing it will let the bowl come out at the bottom of the fixture so you can get at the bulb. You will probably need a short-handled screwdriver to get in under the motor housing. There are also three #2 Phillips screws going into the side of the cylindrical section below the fan blades at the bottom; this section has the fan and light chain-operated switches attached to it. Those probably attach the entire light fixture to the rest of the fan.
Jun 25, 2014 | Dryers
How can i reset my rohs aquarium led light
Be very careful. Mine started making a knocking sound and a few minutes later flames came out of the side of it. Thank God I was home and put the fire out. Light is only 5 months old. If you purchased fromaquatraders, I would request a refund and return it. They are bad about selling defective odyssea fixtures
Dec 19, 2012 | Better Light 120W LED Aquarium Lights CE...
Hampton Bay Mercer ceiling fan keeps buring out bulbs
Halogen bulbs are a lot hotter than other bulbs and have a much shorter life span. It is the nature of the bulb. You can see about changing just the lighting fixture on the fan or look into getting an LED bulb, they run very cool compared to halogen and last forever.
Nov 26, 2017 | Hampton Bay 24002 Ceiling Fan
Panasonic TC-P50VT25 1 yr 3 month old powers off after 30 secs blinks 11 times pauses blinks 11 times and continues
The issue suggests either no voltage to that fan or it is bad--most of these all fans are powered from the same source.
I have seen this before---try swapping fans if they are identical--if another where you swap it now does not work--fan is bad.
Usually we (in the shop) if find this change all three fans.
Mar 20, 2012 | Televison & Video
How much, i supost to pay for one of these
Hampton Bay is sold (almost exclusively) by Home Depot. Pricing seems to be about $190 give or take a little. Of course, it may go on sale for substantially less from time to time.
Installation costs can vary significantly based on your geographical location, whether an older fan or light fixture is being replaced by this fan or if this is to be a new electrical device in the ceiling. Additionally, the distance from the power source, switch and fan are from each other, and other variables as well. You best bet is to contact two or more local electricians to get an estimate of the cost for the installation work.
The price should include installation, permits & inspection fees. I hope this helps!
Dec 03, 2010 | Hampton Bay B552ODWH Gazebo Plus Ceiling...
I have a hampton bay ceiling fan & light,carriage house 52", white. the light fixture is loose, it feels like it is ready to fall. is there any way of thghting so it will not fall
Depending on where it's loose it would be tightened with the nut on the shaft/pipe going into the bottom of the fan or, tightening the screws which fasten the housing to the light fixture is -- these will be in the side of the lower cup which connects to the fan housing.
Charlie
Aug 31, 2009 | Hampton Bay 52 In. Polished Brass and...
Fan cuts off for no reason
It could be the capaciter, found in the light fixture area.
Aug 19, 2008 | Hampton Bay 04379 Madison Avenue Ceiling...
Hampton Bay B552ODWH Gazebo Plus Ceiling Fan Logo
125 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
