I have a Brother Fax/printer and havn't used it for a while everything seams to work except the keyboard for dialing and setting up function selection. Only the 2,3,6 and * keys are working. Any suggestions please? Regards, Colin Ifield
    Scholar:
  • 159 Answers
You have a stuck key. Only trial and error will tell you which one. Try pressing them all a few times and see if you can free it up.
Posted on Oct 06, 2010
Everything is working fine on my lexmark all-in-one except for the fax. It is dialing the number and says that it is connecting but will not connect. Have cut it off for a period of time then cut it back...
It could be the fax line in the wall. Try to insert a telephone straight to the wall and listen for a dial tone. If you hear no dial tone, please contact your phone company and have them check the line. If you hear a dial tone, re-plug the printer into the wall using a different known working telephone cable. Try to fax again.
Aug 26, 2011 | Lexmark X4250 All-In-One InkJet Printer
MFC-490cw Color Inkjet Multi-Function Printer: how to send a fax...
Most of these will send a fax without even using the PC. Just connect a phone line, place the document in the proper position, usuallu print side up on newer models, and push the fax button, it should prompt you for the number. Once dialed,, the paper will feed into the scanner portion of the multi, and you will see it on the menu bar saying sending page 1, 2 etc, after if is done sending, it will dial and connect, yu should hear the typical noise a fax makes. then it will say fax sent or end or something similar, that's it, try sending one to a friend to make sure it's working. Now some simpler machines require you to open the scanner portion and lay the paper down in the glass manually, mine does it both ways. In that case just skip the feeding part, and dial wait for it to scan and send.
May 16, 2010 | Brother MFC 490cw Color Inkjet...
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
Busy/No Response
Using a cell phone, call your fax machine to see if the fax answers. If it does answer, then hang up the cell phone and fax. Next, using the HOOK button on your fax, call your cell phone . The cell phone should ring and answer the phone call from the fax. If you do not get a connection between the fax and cell, try these: Check that the phone line to the fax is plugged into the LINE jack on the fax, NOT THE PHONE jack. The PHONE jack on the fax is to plug in a TELEPHONE ONLY. If the fax phone line is OK, go into your fax machines' RECEIVE and SEND settings and make sure they are set up properly (pulse or tone dialing, overseas mode, etc.) Print out the HELP LIST as follows: Press MENU button, then 5 on keyboard, then 1 on keyboard. Go through all the settings on the HELP LIST that apply to your problem. (Send and Receive modes, Ring Delay, Receive Options,etc.) Write down the original settings BEFORE YOU CHANGE ANY OF THEM.
Aug 25, 2008 | Brother MFC 420CN All-In-One InkJet...
Fax not working
might be a hint:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
else
call brother hotline of your country because of so many diffrent tel techniques.
Mar 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
49 people viewed this question
jasbo
jasbo
