Question about Microsoft Xbox 360 Console
Some discs get scratched while in console - Microsoft Xbox 360 Console
  • 767 Answers
This is not as common as it use to be, but I have found that
in some instances a reflow of the C.P.U. not the G.P.U. seems
to resolve this problem . the other cause of what's called( over shoot of the lasers focal assembly) is the drive is malfunctioning and
developing a glitch , in this instance the drive board will need to have
code extracted from it and then re-flashed to a new drive and that
almost always resolves this annoying little problem . If you have
any questions feel free to ask . Please rate this tip since I seem
to have a lot of unrated tips ,
Thank you
Rob
Posted on Oct 06, 2010
WHEN I GOT A NEW GAME IT WAS WORKING BUT A COUPLE OF DAYS LATER IT SAID THE DISC COULD NOT BE READ AND IT TOLD ME TO CLEAN IT WITH A SOFT CLOTH AND RESTART THE CONSOLE AND I DID IT AND IT SAID THE SAME...
Check to see if there are any scratches or laser burn marks on the discs. If there no scratches evident on the disc, try a laser lens cleaner, these are normally quite cheap.
Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc. This occurs to discs when the games console has been moved whilst playing. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on XBOX disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the "More Info" & "FAQ" Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the disc is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
May 20, 2010 | Microsoft Xbox Console
My Xbox 360 keeps scratching my game discs?
Sounds like the xbox console needs the laser adjusted or secured as per the other comments. For any discs issues, read on.
Check to see if there are any scratches or laser burn marks on the discs.Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
www.discREPAIR.ie
Hope this Helps!!
Apr 07, 2010 | Microsoft Xbox 360 Console
My disc is scratched because i steped on a cord
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on Xbox & Xbox 360 disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters, or send your discs for repair.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Apr 06, 2010 | Microsoft Xbox Console
My xbox fell standing up and my game said when i turned my xbox back on the game can not be read
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally required to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 disc repairs, visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
Hope this Helps!!
Feb 16, 2010 | Microsoft Xbox 360 Console
Scratched discs
www.discREPAIR.ie
Hope this Helps!!
Jan 17, 2010 | Microsoft Xbox 360 Console
Xbox360 seems to be scratching discs
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally rerquired to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 laser burn disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
You can send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
If this is happening consistently without any knocks or movement of the console, I would contact Microsoft for advice on your games console.
Jan 11, 2010 | Microsoft Xbox Console
Halo ring on disk.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is usually required to repair any scratches or laser burn on discs.
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters or to get scratched discs repaired back to "As Good As New Condition".
Hope this Helps!!
Dec 29, 2009 | Microsoft Xbox 360 Console
Disc ring
While disc scratching is known to occur if you move your XBox360 console from vertical to horizontal position while the disc is spinning or by bumping the console while the disc is spinning, there have also been reports that discs have become scratched when the console has not been moved at all. The official line from Microsoft is: "If you are experiencing scratched discs without moving your console you should contact 1-800-4MYXBOX for warranty support from Microsoft." Unfortunately, Microsoft will not replace your scratched discs for free. Instead, they offer a scratched disc replacement program with a charge of $20 per disc. To take advantage of this program go to the XBox website and search for "XBox Disc Replacement Program".
Apr 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
