Question about Philips Audio Players & Recorders
I have purchased a new Philips DSP 3300 hometheater. I have installed the same. However I have not connected the DVD player to the TV and have not changed its factory setting. Its conencted as is from the box. When I play a CD the audio is coming only from the front two speakers. The center and rear speakers and subwofer are not playing any audio. Please help. Best Regards - Chinmay Patnaik
I have purchased philips dvd and philips home theater 5.1 3300w model. how to connet to the home theater to dvd and tv. because i miss my home theater manual book.
Posted on Nov 23, 2010
  • pranshavs Dec 21, 2010
    press the mode button until yuu get the full sound. Its 2nd button of first row
  • Raven Surf
    Raven Surf Sep 27, 2015
    hi, i too have the same model and have lost the remote, can you share the remote control code present in the back of the remote
What is the remote code of dsp 3300 philips multimedia speaker system?
I have a multimedia speaker DSP 3300.but I haven't the remote .Is there any way to operate it.
Jul 25, 2012 | Philips Audio Players & Recorders
Dennon AVR 3300-- problem is the input signal (digital optical connections) for DVD and TV is no longer being "lock" or recognized
hi Check IC403 on the AUDIO/DSP unit. I have had it cause some input problems. If pressure is lifted on the ic then it will break contact on the board. It may just need to be reseated or the socket needs to be re-soldered.
Hope this helps.
Jul 03, 2011 | Denon AVR-3300 Receiver
I have setup the DSP3300 hometheater. However when I play a CD, the audio comes from the front two speakers only. However there is no audio from the center speaker, rear speakers and sub woofer. Please let...
Unless the CD has DSP encoded sound, you will only get the usual CD stereo (2 speaker) sound, unless your receiver is able to apply DSP FX to a stereo source.
Oct 06, 2010 | Audio Players & Recorders
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
Problen in installation....
You have to make sure that the video output from the DVD player is connected to a video output unit which could be your TV, or if your computer has video inputs you might connect your DVD player to it. Then you have to set your TV or computer to the correct display. For example if your DVD player is connected to the VIDEO 1 input of your TV, you would use your TV remote to set your TV to VIDEO 1.
Jul 07, 2009 | Philips DVDR520H DVD Player/HDD
How to Connect Converter to TV, DVD/VCR and a Stereo?
Connect converter box to your DVD/VCR player at the ant in. Depending on your location you might need a new ant for UHF.
Jun 15, 2009 | Philips DVDR3435V/37 DVD Recorder/VCR
HOW to hookup,connect, dvr cablebox to DVD,VCR Recorder(Panascnic)threw HomeTheater ?
Connect cablebox output video cable to DVD recorder input. Connect Audio cable to Home theater. Connect DVD Recorder output to TV.
Hope this helps!
May 02, 2008 | Televison & Video
Installing or connecting my dvd player to my television
if you're using a simple connection, connect the yellow colored output connection of your DVD to the video input of your TV. The audio out of the DVD red and white will go to the red/white of the TV also. If your TV is one channel or monaural, then you can only connect either the red or white.
you can also makje the connections in stereo if you are using a DSP amplifier. in that case your DSP should also have a video input and that is where you will connect your DVD. The video output of your DSP will go to the TV input. Just remember the color, Yellow is video signal )composite) and Red/White for left and right chanel audio.
Jan 05, 2008 | Aspire Digital AD-900 DVD Player
Need help with DVD hookup
What connectors do you have on the back of you television? If it has the 3 red white and yellow ones then you can get an scart adapter and leads to connect it.
Dec 29, 2007 | Televison & Video
1,079 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
