Turn the ps3 off when it goes red press power button till it beeps twice and then turn it on and the picture will be on your screen that reset your ps3Turn the ps3 off when it goes red press power button till it beeps twice and then turn it on and the picture will be on your screen that reset your ps3
You can't post conmments that contain an email address.
PS3 is one of the most amazing gaming device but like other competitor gaming
devices (Xbox and Wii) It also has some problems like No Display Problme. You
may check out the informative blog post at PS3
Repairs blog
Try to reset the PS3 as specified in the manual , if no power is available then it is possible that the power supply has failed. Please ccheck this link for tips to check SMPS units.
Make sure the HDMI cable is connected to the HDMI OUT port on the
back of the PLAYSTATION 3 system. Connect the other end of the HDMI
cable into the HDMI Input port of the TV or display monitor.
While the PLAYSTATION 3 system is in standby mode (red light on the
front of the system), hold down the
touch-sensitive power button on the front of the system until the system
goes into standby mode again . (So the light cycle would go from:
red light --> green light --> then back to red light). This
will ensure that you have held down the power button long enough to
reset the Video Output Settings.
Turn on the PLAYSTATION 3 system and once the system finishes powering
up, the Video Output Settings will automatically reset to the standard
resolution (or detect the current display output settings of your
TV/monitor).
when playstaion is in standby (red light on), hold down the power button until the ps3 beeps a 2nd time then release the power button.
This should auto detect your tv again and hopefully fix the problem.
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Simple mate. When your loading up the playstation, hold the power button, until you hear the second beep, and it should restore to it's original settings.
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like No Display Problme. You may check out the informative blog post at PS3 Repairs blog
I look all over the net but could't find anything, until i found a site that said they could show me how to fix any problem with my ps3. At first i was not so sure about ordering the manual but i did, whats $5 plus i used paypal, but long story short i fix my ps3, i recomend this site www.gameme.20fr.com i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
hold down the power button untill it beeps twice. about 3 seconds which should restart the settings to the default composite settings. from there you can change the settings back to hdmi or whatever you had them at before.
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
shows no picture and it wont insert a game
my ps3 wont show a picture even though the power is on
