I have setup the DSP3300 hometheater. However when I play a CD, the audio comes from the front two speakers only. However there is no audio from the center speaker, rear speakers and sub woofer. Please let me know where did i go wrong. Pl Note: The DVD player is not connected to the TV and I have not changed and factory setting. I have just plugged the new hometheater to the new DVD player. Best Regards - Chinmay Patnaik
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Unless the CD has DSP encoded sound, you will only get the usual CD stereo (2 speaker) sound, unless your receiver is able to apply DSP FX to a stereo source.
Posted on Oct 07, 2010
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
I have purchased a new Philips DSP 3300 hometheater. I have installed the same. However I have not connected the DVD player to the TV and have not changed its factory setting. Its conencted as is from the...
i have purchased philips dvd and philips home theater 5.1 3300w model. how to connet to the home theater to dvd and tv. because i miss my home theater manual book.
Oct 06, 2010 | Philips Audio Players & Recorders
My Dell A225 Speakers do not play audio- just the computer sounds.
Test this setup with your walkman/ipod.
The most likely problem is in your computer's mixer selection.
Put a CD into your computer drive and play this CD.
If the CD audio output is low then dial up the mixer CD output.
If you do not has audio via CD at all then the CD drive to sound card audio cable is disconnected.
Jul 08, 2010 | Dell Audio Players & Recorders
When I plug every thing in we only get full sound out of 2 of the speakers
Go to the sound test/speaker setup page, this will produce a sound out of each speaker one after the other, it will confirm that all speakers are correctly connected.
Depending on what you are playing through the unit the audio track may only be in stereo, which may explain why only 2 speakers are used.
You require an audio track in Dolby Surround/Dolby Digital etc for multiple speaker output
Mar 02, 2010 | Coby DVD-755 System
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
JVC SXXSW6000
Hey there, I have some information that may be able to help you. You don't have a Optical Output for you system but that does not mean you can not hook it up to your TV directly. Or if you got a fancy Receiver on your hands you can hook it up to that too. All you'll need is the Audio cable that will connect your Hometheater System to your TV or to your Receiver. Its very easy hooking it up. If you have any more questions or anything like that let me know.
Jun 26, 2008 | JVC SXXSW6000 Speaker
Music won't play through speakers
Please provide more detail of your system's setup and connections. Thanks!
Mar 05, 2008 | Alpine CDA-9855 CD Player
 Grubhead
Grubhead
