Question about Fuji FinePix F650 Digital Camera
When i turn it on it say zoom error like its jammed
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Camera zoom does not work
that is an error condition on the lens
take it back its jammed
Apr 19, 2014 | Fuji Film FinePix JX500 14 Megapixel...
"Turn the power off and on again" error message
the lens zoom ring is jammed, or broken , if the zoom looks broken just try to staighten it, you will hear a breaking kick noise, but it might work unless it is already broken which might require a professional service.
Dec 09, 2013 | Sony Cyber-shot W290 Digital Camera
My new panasonic lumixDMC-ZS8 14.1MP Digital camera gives me system error (zoom) when I turn it on.the lens will not open?
The systems control board has detected a fault wth the lens, over time dirt and grime collect in the len causing havoc, the other concern is the gears have jammed or got damaged, either way it is a major dis-assembly and it will be expensive.
Mar 20, 2012 | Panasonic Cameras
When I turn camera on it says zoom error! How do I fix the problem?
Try playing with the zoom in and zoom out buttons it usually comes from a a jammed zoom lens.
you also may want to try helping it out.
Mar 02, 2011 | Fuji FinePix A900 Digital Camera
Zoom lens is stuck
This is a very common problem. This is either caused by something jammed in zoom, or the firmware needs to be updgraded which is common also.
Sep 10, 2009 | Fuji FinePix A800 Digital Camera
Zoom error
The lens mechanism is jammed or broken, the camera needs to be taken apart and inspected. As these kind of  things may break easily oyou might not get it back together..... so try replacing it...
thank u rate me!!
Feb 10, 2009 | Fuji FinePix F650 Digital Camera
ERROR REMOVE CAP LENS
I had the same problem with mine after I dropped my camera when it was opening up after turning on. It feel directly on the lens and ever sense has told be to remove the lens cap.
I’ve disassembled the camera and discovered that the zoom motor drive assembly has a small set of plastic gears inside that are quite fragile and like mine are easily broken. You’ll find the zoom motor after taking the back assembly of the camera off. It’s located on the bottom left side of the lens assembly if you're looking at the camera as if you were taking a shot.
Here’s the part no. from the Panasonic support web site.....
L6DAAAHB0001
ZOOM MOTOR
46.07
May 28, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Fuji FinePix F650 Digital Camera Logo
88 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
