Question about RCA D52W19 52" Rear Projection Television
RCAHD52W59 convergence/flyback Hi, I got my set torn apart and found the bad fuse (FL231) got a new one on order. I resoldered the pins on the bottom of the flyback, hope I got them all around 6 or so in a half circle. Is there anything else I need to do before soldering in the new fuse?? One tech advised bypassing the fuse with alligator clamps is this advisable.
  • RCA Master
  • 5,138 Answers
NOT really but when you reconnect ribbon connectors make sure you have prober connection or set will not firer back up its the 2 connector that controls this, also for convergence its the middle fuse that blows and also look at fuses next to tuner on signal broad sometimes they will blow shuting down tuner.If you need anymore help let me know.PS I have used thin wirer to jump fuse.
Posted on May 31, 2008
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from www.tvrepairworld.com
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
Turns on picture distortd and curved in three color lines at top cannot get to convergence
Go to menu then setup if you do not see convergence listed then you have a blowed fuse FL231 it will be on deflection board which is bottom board on left side it has FBT flyback transfomer on it and on the right side of FBT is 3 fuses in a roll they look like small brown rectrangler caps but they are fuses 0.6amps it will be the one in the middle Call Partstore.com for Part 1-866-925-7278 or look it up online .
God Bless and have a wonderfull day.
Nov 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
R52wh74 already changed 231 fuse still not converging
Did you change DL231 and CL230 with the fl231? Also did you reflow the solder on the flyback and vertical IC? Bad solder is what blows the FL231, but without changin DL231 and CL230 and resoldering the flyback and vertical the fix wont be fully effective.
Jun 12, 2009 | RCA R52WH73 Projection Television
I have a RCA HD 52in and I'm have a problem with the Convergence Ic's
Hi, rca`s don`t have convergence IC`s, they use an entirely different system to perform convergence, you have a blown chemical fuse and 3-6 bad solder joints on your flyback transformer. replace fl231 chemical fuse rated at 400ma. right beside flyback (theres 3 of them your bad one is the middle one)and while your soldering re-solder all of the flyback transformer pins and your tv will be back to normal :) video-tek
Jun 04, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence menu not available on my RCA HDTV. Model R52WH74YX58 I have installed all 3 new fuses as well as DL231 and CP230 and resoldered the pins on the flyback and IC, but I still have not got an...
The only fuse that will govern the convergence option is FL231 along with the two other components that you mentioned. If that didnt fix the issue the deflection board or the convergence power supply is defective. The deflection board is most suspect.
May 26, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence nightmare
If this is a ITC222 chassis then you need to check the fuses that are near the flyback. I would also unsolder all the pins on the flyback and re-solder them as the factory lead free solder tends to crack and cause issues with the convergence. Re-solder it with common 60/40 solder you can pick up from Radio Shack or other places.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
