Question about Premier Water Heaters
How do you chage the thermal coupler - Premier Water Heaters
  • 4,350 Answers
You buy a new one, unscrew the old one and install the new one, What is important is to not kink the tubing, and the location near the pilot, install the new one same adjustment (location) as the old one and you should be good to go.
Posted on Oct 06, 2010
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
I have a vanguardd model cfp1000bt and the pilot wont light what do i do ?
You might have a bad thermal coupler.thats the little rod that the pilot flame heats
Dec 15, 2013 | Water Heaters
Have a Baxi solo boiler 340PF, have hot water but no heating, pilot light will not stay on. how do I fix it so I get heating please?
it might be the thermal coupler....it is a piece of wire that goes from the pilot to the thermostat. very inexpensive. .I am a 50 yr old woman, and I changed mine on my furnace twice..Home Depot or equivalent should be able to help. Google "thermal coupler"
Jan 22, 2013 | Water Heaters
My bolier gas supply is going on and off while the water is on
if the flame keeps shutting on and off while running hot water. it is more likely to be a failing thermal coupler, here is what a coupler does- it is always in the pilot light flame which acts like a thermometer. it goes from flame to the gas control, if it is failing or has failed, it will shut the gas off. as a safety precaution.
Jun 07, 2012 | Water Heaters
THE PILOT LIGHT WILL NOT STAY ON.
Check your thermal coupler, this may need replacing.
Dec 03, 2010 | Whirlpool Water Heaters
How to repair a thermal coupler on a 1994 gas water heater
Time to get a new tank. The life expectancy is between 10-15 years. You are probably spending more in natural gas to heat than the tank is worth.
Jul 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
My hot water tanks pilot light turns off after I have relit it. It stayed on while heating the water in the tank and once it stopped heating the pilot light went out again. What would be causing my...
are you holding button down long enough for thermal coupler to warm up? after pilot lights up, don't immediately let go of button for about 15 to 20 seconds then let go and pilot should stay on. If not, you may need a new thermal coupler for that water heater
Jul 03, 2009 | Water Heaters
Water Heaters Logo
137 people viewed this question
Top Premier Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Premier Water Heater Expert? Answer questions, earn points and help others
