Question about Canon imageRUNNER C3200 Copier
I have a canon iR3225 with e000733-0000.I replaced both the dc control and main control pcb's but did not solve the problem,Can any one help? Tsilo
  • 67 Answers
SOURCE: E013 - 0002 Do I have to replace the DC controller PCB Board?
clean your waste toner pipe by using a vaccum you also haveto hit it to break up any hard toner build up replasce the bottle take machine off then on again
Posted on Nov 27, 2008
  • 57 Answers
SOURCE: help me.....faster....
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Posted on Dec 25, 2008
odiegh
  • 81 Answers
SOURCE: Canon Gp200 Error Code E000-001
I looked up the e000 and it said it's for the fuser using not heating up and 001 error code and it is that the fuser unit is overheating. So seem to me you have a bad fuser unit.
Posted on Jan 02, 2009
SOURCE: E000003-0000
That was AWESOME!!!!!!
I feared I would have to outlay big bucks for this error. But low and behold, I did a G**GLE search - and found this!
Worked like a charm..Thank you very very much!
Posted on Jan 28, 2009
  • 700 Answers
SOURCE: I need canon gp 405 Service manual that contain
this site have service manual which contain most of requested bits, including how to and what to do. it is not for faintharted do... :-)
http://www.scribd.com/doc/16699855/Canon-GP405-service-handy
if you find my answer helpful, please rate it, thanx!
Posted on Jul 31, 2010
Hello sir I have canon ir 3300 in this code error is 000001-0002 so how can I solve this error
http://printcopy.info/?l=en&mod=erc&brand=canon&model=ir3300&code=E001-0002
Quoting from internet link:
Exploded Views and Parts List Free!
Code
E001-0002
Description
The sub thermistor detects about 295C or higher
Causes
The fixing film unit is faulty (i.e., the thermistor has a short circuit). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service move: COPIER>FUNCTION>CLEAR>ERR.
Remedy
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 W (short circuit)? YES: The thermistor has a short circuit. Replace the fixing film unit. If the thermistor has a short circuit, the indication in service mode (COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC= 250°C for the main thermistor; FIX-E=310°C for the sub thermistor. 2. Main power supply PCB, DC controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Canon iR3300 Error Codes
May 01, 2018 | Canon Office Equipment & Supplies
Canon ir3300 error code 000805-0002
canon ir2200 E000805-002
E805
The clock signal is absent for 5 sec or more after the fan drive signal has
been generated. The detail codes of the fans in question are as follows:
0001 developing fan (FM1)
0002 fixing fan (FM2)
0003 curl reducing fan (FM4)
0004 curl reducing fan (FM5)
0005 electrical unit fan (FM3)
Main cause The fan wiring is faulty (short circuit, open circuit). The fan is faulty. The
Action
1. Foreign matter
Is there foreign matter that prevents the rotation of the fan?
YES: Remove the foreign matter.
2. Wiring, Connector
Are the wiring and connector of the fan normal?
Developing fan (FM1): DC controller PCB (J302B)
Fixing fan (FM2): DC controller PCB (J308B)
Curl reducing fan (FM4): DC controller PCB (J311B)
Curl reducing fan (FM5): DC controller PCB (J311B)
Electrical unit fan (FM3): main controller PCB (J1028)
NO: Correct the wiring and the connection.
3. Fan, DC controller PCB
Try replacing the fan. Is the problem corrected?
YES: End.
Nov 09, 2016 | Canon Ir 3300 Black & White Copier
How to sol error coad E000733-0001
Error code E000733-0001 on Canon IR2200
E733-0001 means a fault is detected by the main controller PCB in the communication between the DC controller PCB and the main controller PCB.
Main cause: The connector has poor connection. The DC controller PCB is faulty.
Solution:
Verify the connection between the connector J1015 on the main controller PCB and the conductor J316 on the DC controlled PCB is normal.
Correct the connection if necessary.
The connection is correct: Replace the DC controller PCB.
Dec 17, 2014 | Office Equipment & Supplies
The solution for an error code E000733-000
E733
0001 A fault is detected by the main controller PCB in the communication between
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller PCB.
Jun 29, 2014 | Canon imageRUNNER 3225 Black and White...
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
Error e000733
E733
Action
Mar 04, 2011 | Canon imageRUNNER 2200
Error code e000733-0001
E733
Action
Jan 23, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir 2016j
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
E000733-0001 error code
E733 0001 - A fault is detected by the main controller PCB in the communication between the DC controller PCB and the main controller PCB.
Action
1. Connector, DC controller PCB Is the connection between the connector J1015 on the main controller PCB and the conductor J316 on the DC controlled PCB normal?
Nov 13, 2009 | Canon imageRUNNER 5000 Copier
Error261 in canon copier
E261
0000 The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
Making Corrections
1. Connectors
Are the connector J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected? (zero-cross signal:
J205-7 <-> J308B-1)
2. Main power supply PCB, Main controller PCB
YES: End.
Feb 22, 2009 | Canon NP 7130 Black and White Copier
Canon imageRUNNER C3200 Copier Logo
427 people viewed this question
old marine
old marine
