Question about Panasonic DMR-E75V DVD Player/VCR
DMR-E75V Hi, I have one of these drd/vcr recorders and am having trouble with the dvd half. Just recently it has started rejecting disks (even brand new unused ones) it starts recording/playback and then stalls and shuts the system down. It will then tell you the disk needs reformatting which I have done but sometimes it then states unable to format and finally it responds with 'this is not a recordable disk - even ones it has previously recorded on. The first few times the problem appeared resolved by rebooting the system and I have just resorted to leaving the system unplugged overnight hoping it would sort itself out but it is still causing problems. Sometimes although a dvd has been reported as unformatable it has gone on to format it (albeit taking a long time to do it) but it would appear once it has reported it as a non recordable disk it is unrecoverable so I now have a pile of several disks which seem to have been destroyed by the recorder (including some brand new ones). It would appear that the dvd system has completely got its knickers in a twist whilst the vcr side of things is fully functional. Any clues/suggestions as to what could be the problem and possible resolutions would be appreciated. Kind regards Lynn Higgs
Same issue here. Ive tried diff disks, unplugging, blow-off, laser cleaner. I am wondering if it is temp related since it seems to work better in out thin air cool nights. I have adjusted its position to alow better airflow and may take a cold shower myself. Jim in BerqueNM
Posted on Aug 23, 2008
Panasonic VCR/DVD combo - stopped recording sound
Seek tech support. This is not a self repairable work. Need technical skill.
Jun 02, 2012 | Panasonic DMR-E75V DVD Player/VCR
I have the DVD/VHS recorder/player Panasonic Model DMR-E75V, I have connected the 2 scart cables to the digital decoder and TV set but I cannot record even if I can play the VHSs and DVDs normally. It's a...
First of all you have to connect only one SCART cable ( one end to TV and the other to DMR ).When you are watching a program on TV select the DMR source ( input selector ) to SCART. Just press the record button with a blank DVD inside and it will record. Some Digital broadcast might have copy protect content which will prevent the recording from happening.
Mar 10, 2011 | Panasonic DMR-E75V DVD Player/VCR
All dvd-ram, even new, apear to be protected, locked. I can not modify this status from 'disk management menu'. I can not record on them
You cannot record on ANY disc in this unit? Protection on? I have a DMR-EZ48V with the same issue. Protection ON - RW DVDs not recognised. From recent experience, I am advised that it is the DVD-RAM drive, this is not a serviceable part, it must be replaced, and the existing firmware upgraded/reset by an authorised service centre. Only a workshop with the right facilities can restore the record function in these combos, if it indeed CAN be restored. Panasonic are aware of this as a common problem but they cannot explain it. Not economical or cheap via this option - as new DVD drives can cost anywhere around $400+ plus labour!
Is it worth taking to a repair shop to get a FREE quote on likely costs? It's up to you. I don't want to feed you anything here, except what Panasonic Australia have informed me about.
Jan 28, 2011 | Panasonic DMR-E75V DVD Player/VCR
I need help with recording VHS onto DVD with my panasonic DMR-E75v
it is probably best to use a professional company to do this rather than risking your videos being damaged. try www.vhsontodvd.com, i have used them before and had no problems. Thanks
Jul 15, 2010 | Panasonic DMR-E75V DVD Player/VCR
Panasonic DMR-E75V Dubbing Problem
you will need to finalise the disc in your DVD recorder before it will play on any other equipment
Nov 18, 2009 | Panasonic DMR-E75V DVD Player/VCR
Compatible dvd-r discs?
I've never had much luck with DVD-R's but the DVD+R's that I've used work just fine; Verbatim and TDK have both worked.
Jan 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
DVD RAM PANASONIC DMR-E75V WON'T ACCEPT NEW RAM DISKS
Make sure the DVD RAM is in the plastic caddy that came with the unit, and make sure that caddy is marked unprotected.
Dec 14, 2008 | Panasonic DMR-E75V DVD Player/VCR
How To Burn a DVD from VHS tape
Insert the VHS tape. Do not press play. Insert a DVD RAM or DVD-R into the DVD side and press and hold DVD DUBBING, it should start playing the VHS immediately while recording on the DVD side.
Jun 03, 2008 | Panasonic DMR-E75V DVD Player/VCR
Panasonic DMR-E75V DVD Player/VCR Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
