Question about Sylvania Televison & Video
Model SSL2006 will not accept TV (cable) channels above 13.
  • Anonymous Mar 24, 2014
    How to sset up channels
  • Sylvania Master
  • 1,229 Answers
You must be sure you are in connection with the menu. Read the menu and find [video source] antenna/cable. Be sure you are in "cable" source. And then program your TV for channel search! Try this, and thanks for asking!
Posted on Oct 06, 2010
Can not get channels above 77.
Is the TV cable ready?
Dec 14, 2009 | Cars & Trucks
I can't program channels above 13
Check your TV settings and be sure to set the tuning mode to cable (sometimes it says CATV). You will find it's set to "air" now. When set for off-the-air tuning, cable channels 2 through 13 work fine, but above that you get nothing. After you set your tuning mode to cable, rescan channels and ou should have everything.
Apr 01, 2009 | Toshiba CF20F40 TV
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
In auto program only the first 13 channels are found?
sounds like bad tuner try to program manually and see if it will hold memory
Mar 20, 2009 | Zenith Z32X31D 32" TV
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
CATV access
you need to hit the input button on your remote to CATV and u will get the cable channels
Jul 16, 2008 | Emerson TC1351 13" TV
Cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Jan 06, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
GE TV model 25gt239
i have one , to watch DVD or VHS by the audio Video Compenent, from your remote control pess ( 00 ) 2x zero, thanx.
Nov 25, 2007 | Televison & Video
GE TV model 25gt239
I think your TV is made by RCA and it should go to cable channel 125. If Comcast has any channels above 100, you should be able to get them. RCA TV's have a problem with the solder connections inside the tuner. This may be your problem. If this is the case the tuner would have to be taken apart and re soldered. Stargazer
Aug 31, 2007 | GE 25GT240 25" TV
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Televison & Video Logo
119 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
