Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Hi, I own an Ariston frontloader washer dryer, AML125. The handle has broken of the door. can you please tell me how this can be repaired/ remedied?
SOURCE: Ariston AWD 120 Door Handle is Loose
unplug it.
open the top lid.
reach down inside and feel a plastic sensor/release behind where the latch is.
towards the left center of that sensor, feel for a metallic manual release (you'll just feel the nub of it).
Push this in and to the side to manually release the door lock.
Call Ariston and complain about this common problem.
Posted on Nov 09, 2007
jaylex
  • 417 Answers
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Posted on Feb 05, 2008
  • 5 Answers
SOURCE: Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Posted on Feb 07, 2009
barkencoa
  • 3463 Answers
SOURCE: Broken door handle on washing machine
You can purchase any of the parts individually for the door handle.
If you go on line and enter Ariston door handle in search box, you shuold be able to locate the part/s you require.
Good luck.
Posted on Jan 06, 2010
lgdinesh
  • 35 Answers
SOURCE: door handle on ariston awd12s has broken how i can
open the table top of the machine and release the door switch by any flat screw driver
Posted on Jun 06, 2010
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Door handle on ariston awd12s has broken how i can i get the door open
Jun 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Good luck.
Jan 06, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Door latch broken
Look in yellow pages if you are in the U/K, and ring Hotpoint service, who are the service agents for Ariston.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Can I connect my AML125 to hot water
Not advisable if it is a cold fill washer only, as you will then be rinsing in hot water, and this could cause shrinkage of clothing and other adverse effects..
O/k if it is hot and cold washer.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
unplug it.
open the top lid.
Nov 04, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
104 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
