My computer doesn't connect the printer - Office Equipment & Supplies
  • 386 Answers
Hi Good day! Please check the printer cable if its properly connected.. then do the following..
1. Click "START" then "Setting"
2. Click "Printer and Faxes" then you will see the printer and faxes box.
3. Go to the "Print Tasks" and click the "add printer"
4. Then you will be in the "Add printer wizard box"
5. Click "Next" and then select the "Local Printer attach to your computer.
see if your computer detects your printer. when it does click your printer and then install it..
hope it works...
Regards:
JR
Posted on Oct 06, 2010
Can I fax with my HP c4280 All In One printer
Not directly. The C4280 doesn't connect to a phone. You can scan a document on it, then fax it from the computer if the computer is connected to the phone system.
Jul 14, 2012 | HP Photosmart C4280 Aio Printer
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
When I connect the printer esp5 to the computer it doesn't seem to recognize it, why?
remove the cable and insert again.if it doesn't work change the cable
Oct 29, 2011 | Kodak ESP 5 Printer
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
Wi-fi connection has stopped working. Green light is steady but will not print. Get message saying the computer and printer can not connect.
You need to plug in the original USB cord that came with the printer. Once that is done, try again, the computer should re-dectect the printer. If it doesn't, then a security setting on your wireless has recently changed. If so, then you need to re-run the setup that came with your printer.
Aug 30, 2011 | Dell V313w AllInOne InkJet Printer
DETAILS DONT SPECIFY WHERE TO CONNECT PRINTER- APEX AX3400G-U4802 computer
As this doesn't machine doesn't have a Parallel Port the only way to connect a Printer is via the USB.
If you've only got a printer with Parallel connection you need to get a Parallel to USB Adapter.
There are 2 types of Adapter depending on what type of connection your Printer has (examples at links below).
http://www.amazon.com/Sabrent-SBT-UPPC-Parallel-6-Foot-Printer/dp/B0007UVRVO/ref=sr_1_1?ie=UTF8&qid=1310762929&sr=8-1
http://www.amazon.com/Cables-Go-16899-IEEE-1284-Parallel/dp/B000UX21PY/ref=sr_1_2?ie=UTF8&qid=1310762929&sr=8-2
These are just examples to show you the 2 types and cheaper options are available.
Jul 15, 2011 | Computers & Internet
Lap top fires up and then just sticks on the Acer logo, Any ideas ?
Hi there!
Is there any USB device connected to the laptop like printer, USB memory stick, scanner, etc? If there is, I suggest you remove it before starting the computer.
If there's nothing connected to the computer then it is a possible hardware problem. If you know how to open the computer, I suggest to remove the memory and place it back. if that doesn't work, it might be another hardware causing the problem. Call ACER so they can help diagnose the problem. If the computer doesn't warranty from ACER, I suggest to bring it to a qualified technician.
Hope this helps.
May 21, 2011 | Office Equipment & Supplies
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Computer can't communicate with printer
whatever be the OS, get into control panel, go to printers and see the printer that you are using is set as default,,, there would be a check mark on that printer icon,, if not make it default,, and try again, If you are using a usb cable connect the usb cable of the printer to the back usb ports and try,, use the printer driver disk that came with your computer, perform a reinstallation of the driver
Feb 05, 2009 | Lexmark X2470 All-In-One InkJet Printer
Hp photosmart 7850 doesn t make conection whit my hp pc
Do you have windows xp for os ???? If so deinstall your printer on your computer and disconnect your usb connection.
First install the driver by putting your cd in your computer...Some product will tell you when to connect your usb cable to your computer...if not, make sure your driver is correctly install. After, reboot your PC and plug-in your usb cable and power up your printer....
Mar 26, 2008 | Office Equipment & Supplies
164 people viewed this question
k24674
jasbo
jasbo
