Question about Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7300dn
All of a sudden while printing a job, the toner stops fusing to the page completely. I printed the Supplies Page and it says the Transfer Unit (Maintenance) 30%. So, immediately I think it is the transfer unit and order a replacement. I just put it in and printed about 50 pages. It started the same thing... streaked toner and some just not sticking to the paper making a huge mess. I run the Remove Smears option and it cleans it up after about 5 or 6 runs until I go to print something colored again.
My question is what does it mean when the diagnostics says "(Maintenance)" on the Transfer Unit even after a new one is put in?
And, do I go ahead and replace the Fuser even though it says it has 40% life left?
Thanks
  • Joe Downing May 28, 2008
    I mean't to say that it printed the 50 pages just fine. It was after the print job ended and a delay in starting the next one is when the streaking began again.
    Sergeant:
  • 406 Answers
Dear try upgradiing the firmware. And if possible contact authorised service center for further assistance. Else update for further assistance
Posted on May 28, 2008
Have Xerox 7300DN Printer. I am getting white lines in black color only. Have done all steps in the Xerox Diagnosing Print-Quality Problems page. Did not solve issue. Supplies usage page states black toner...
It looks like you may have some damage to the black IU. If you have an old one or a spare to try as a test that might help. The drum is easily scratched and this then produces marks or lines in the appropriate colour.
Nov 05, 2010 | Xerox Phaser 7300DN Laser Printer
Out of magenta toner, but need to print in black
normally most printers when you select properties and advance you can select the quality of printing there you can select grayscale instead of color that will do it
steps
click start printers right click properties for pinter select advance change the settings. print a test page will come only black if not repeat steps.
Jul 26, 2010 | Xerox Phaser 7300DN Laser Printer
Fuser seems to be intermittant near center of page
you problem is in the fuser assy. just replace if you have spare.. the problem is that the plastic hinge on your fuser assy roller that is use to control the gap of the rolle.. it is allready worn out the parts allready slips on the plastic hinge, intermitent problem occur of fuse and un fuse print out
Jun 22, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Sep 27, 2008 | Xerox Phaser 7300DN Laser Printer
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7400DN Laser Printer Logo
126 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
