Question about Canon CLC 1000 Color Copier
E061 When I start my "clc 1000" after warmup when i press copy button, after scanning the original document a code E061 displays on screen & blank paper comes out from the copier.
  • 86 Answers
One of your drums is worn is if you repost the sub code i will tell you which drum it is or phone me on 07764303923 if in the uk or 00447764303923 if outside the uk i also have all the tech info on all canon/ricoh models
Thank You
Posted on May 28, 2008
KHOW DO I GET THE PRINTER TO MAKE A COPY OF SOMETHING
No make/model, so here's a generic method:
[based on Samsung Multi-function]
Presuming printer is a MF unit:
Place paper-to-copy face down on the flatbed glass.
Close lid.
Ensure blank paper is correctly loaded in feeder tray.
For a once-off direct 'photocopy':
Press COPY on printer .
For copying (scanning) to a file:
Printer on, drivers installed, blank paper loaded, original on flatbed.
At computer, go to Start.
In search-box type in scan
Left-click magnifying glass to confirm search.
You should see Scan a document or picture appear in icon list.
Click this.
A scanning window should pop up:
Oct 11, 2017 | The Office Equipment & Supplies
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
E061
I bought the machine book and I was able to look at it based on him what it reports the E-061 mistakes.
Myself was able to improve it and now good it's working.
I say thank you for your help nicely.
Jan 06, 2010 | Canon CLC 1000 Color Copier
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Hello, My Canon CLC 900 is showing E061 after it starts up? Any suggestions?
E000–0061, 0071, 0081
1) Clear ‘E000’. Is ‘E000’ indicated immediately after the power
switch is turned on?
• Be sure to turn off the power switch as soon as you have made the
check.
NO: Go to step 3.
Oil thermistor (TH5), Oil heater thermistor (TH6; short circuit), DC controller PCB
2) Turn off the power switch, and disconnect J6019 from J2209 on the
DC controller PCB. Measure the resistance between a and b of the
following table in reference to the detail code; is it 1 Kω?
Code a b
0061/0081 J6019-B5 J6019-B6
0071/0081 J6019-B10 J6019-B11
AC driver PCB
DC controller PCB
3) Replace the AC driver PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Oct 17, 2009 | Canon CLC-700 Copier
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
ERROR E061-0122
e061 is a code for a drum charge error on the first drum in line from right to left i think yellow ? any way its either a worn drum broken charge wire if you have not changed drums in a while the other ones may be coding out next
Jan 28, 2009 | Canon CLC 2400 Color Copier
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
CLC 1120 code e071, sub code 001
there maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors ther may be toner or paper dust.
May 20, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1000 Color Copier Logo
168 people viewed this question
old marine
old marine
