Question about Canon CanoScan D1230U Flatbed Scanner
LHow to clean under side of glass plater - Canon CanoScan D1230U Flatbed Scanner
Note where the dirt is located,unplug all wires from back, remove top hinged cover, undo 2 screws at the top, remove cover plate by gently tipping toward top, slide glass with plastic sides up and out, clean with approved cleaner, reverse to reinstall glass (plug in power cord prior to replacing top cover plate to check for any missed fingerprints or dirt on underside of glass), once your happy with cleaning complete the reassembally.
Posted on Feb 10, 2011
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
EPSON WORKFORCE 840 AUTO FEED COPIES HAVE BLACK LINE DOWN THE SIDE
This was my exact problem. When scanning from the ADF, I had a vertical black line down every page. I cleaned the larger glass surface several times with no effect. Then, I discovered that ADF scans do NOT use the large glass area, but use the smaller, thinner glass area on the left side. It has a piece of thin plastic over the top of the glass. The scanner is fixed and the paper rolls through this area. So, if a speck of dirt is under the thin plastic piece or on top of the glass or on top of the thin plastic, it results in a black line down the whole page. Aha, so now I cleaned the thin plastic (both sides) and the top of the glass under the thin plastic - actually saw the black dot that was causing the problem and voila, problem solved.
Jan 30, 2012 | Epson Office Equipment & Supplies
Cannot get the platter cover off to change the belt on a l-a21 turn table . how do i do this?
Unplug from the mains power & the amplifier phono socket
To remove the plater: first remove the lid - then after securing the arm, FLIP the whole unit over onto the plater (perhaps resting it on your lap) then remove the all the black screws and the brass ones holding the rubber feet in place.
Inside you will find a tube (actually the "pit" for the spindle) undo the (awkward) retaining screw on the tube. At this pint the spindle is now free and would otherwise slide out onto your lap, so just redo all the screws in reverse order -in particular don't forget the Earth wires.
Then holding onto the turntable and plater - flip the unit back over.
The plater will now lift out freely, taking care to unhook the belt from the drive capstan/motor (on the top left) keep hold of the belt with your two fingers (as you have already lifted off the slip matt ) let the old belt slip free and place the new one on the Flange remembering to hold with two fingers as before. the spindle will slide back into the "Pit" (ensure that the bearing has not fallen out) still holding the belt in place hook it over the capstan and under the speed changing device. Try rotating the plater a few times to ensure nothing is trapped untoward, then replace the slip matt.
Re insert Phono lead and then mains power plug.
Place side one of "Goodbye Yellow Brick Road" on turntable and enjoy :)
Aug 04, 2010 | JVC AL A158BK Turntable
I need to clean the under side of the glass.
Cleaning the glass on what we call a "disposable printer" can be interesting. The simple process is to start pulling screws that appear to permit access to the scanner bed. For Lexmarks this generally involves an almost full disassembly of the machine. If you do get it apart be very careful not to let any dust or debris or solvents get near or on the scanner head, this will likely prevent it from properly calibrating and stop the entire machine from running. New all-in-one machines are generally designed so that if one function fails, the entire machine fails. I would say to just purchase a new machine, a repair bill will easily equal that cost and a novice repair job has a good chance of rendering the machine inoperable.
Jun 08, 2010 | Lexmark X5150 All-In-One InkJet Printer
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
paten glass is the copy board glass.try cleaning both side,if still same.it can be off in additional funtion [copy board glass sign.turn it to off ]
Mar 17, 2010 | Canon imageRUNNER 1023iF Black and White...
Need to clean the under side of the glass. Need
I found a service manual on-line that showed the method for removing the glass on the scanner.
Nov 16, 2009 | HP Office Equipment & Supplies
Spilled beer on plater Pioneer CDJ-800MK2
Well, the problem is that you spilled beer on your platter.
More than likely the beer dried up, and now it's all sticky.
Professional cleaning is highly suggested.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 11, 2009 | Pioneer CDJ-800 Turntable
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
HP Scanjet 3400 C
Unfortunately, The 3400 series cannot be cleaned on the underside of the glass. Scanners with the capability of having the under side of the glass cleaned are listed below.
Aug 03, 2008 | HP Scanjet 3400c Flatbed Scanner
Cant get the record to start spinning
The plater is either belt driven or idler wheel driven. You need to remove the plater and check the condition of whichever you have.
Belts would need replaced if bad, sometimes you can clean idler wheels with brake fluid and get them working again. Also if the unit is old, the grease on the plater spindle may be dried up. Clean it off and re-grease. Any light lithium grease is good or go buy some "Luberex" at radio shack.
Geno
Feb 26, 2008 | Philco (R) Classic Turntable CD Shelf...
Canon CanoScan D1230U Flatbed Scanner Logo
894 people viewed this question
old marine
old marine
