Question about GE Refrigerators
I have a TFG20JAXa Total Capacity 627 litres Refridgerator 395litres The plastc drawguides on each sie break under weight of food in draws too easily for my liking and I am wondering whether you have any other material or metal guides for moving Crisper and meat draws in and out.The guides are very expensive to replace and poor quality. This is the 2ndtime they have broken and needed replacing Thanks Sue Davey
bluegreenash
  • 661 Answers
SOURCE: Fridge filling with water
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Posted on Oct 09, 2007
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
  • 1073 Answers
SOURCE: broken rear stationmary support on mat/cheese drawer
yep, order part number 61005337 and part 67764-1 about 2 bucks each and it will fix ya
Posted on Apr 23, 2008
SOURCE: GE Profile PSS25MGMB is too cold
After viewing the pictures of this part on this web-site - I took this part out of my refridge to see if the door was stuck closed or stuck open ( closed = fridge too warm and stuck open is too cold - my problem). The door within this part was broken off the hinge. I took this part apart - styrofoam and tape - and glued the door back together and in place with 2 part epoxy. I reassembled and everything seems OK now.
If this begins to happen again - I will probably just order a new part.
I think it is outrageous that a $700 fridge's performance is regulated by a cheap 50 cent piece of plastic. Spend another dime and make this piece glavanized aluminum? or other material that does not dry rot and holds up in cold dry environments.
Posted on Apr 09, 2009
SOURCE: Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Posted on Apr 21, 2009
1991 2 door suzuki 4x4 vitara towing capacity unbraked
the operators guide covers this.
as does door jam sticker. gross weight, etc.
its 1000 lbs (about)
about 1/2 cars weight total.
see page 8-8
here
http://ge.tt/7WrBuI91/v/0?c
Mar 03, 2015 | Suzuki Cars & Trucks
Vehicle towing capacity chart
A) Depends on the hitch you have and what it is rated for. Most car hitches (non truck or SUV) have a tounge weight rating of 500 LBS. This is the weight that is put on the actual connection of car and trailer. B) To not kill your transmission, do not exceed a total trailer weight of more than 1/2 the vehicles curb weight. (Dry weight of car full of fuel) Car transmissions and frames were not originally designed for towing, and exceeding 1500 LBS total trailer weight is considered dangerous (can get trailer weave and sway easily) and will cause excessive strain on drive train components. U-Haul has an online guide that will basically tell what type of trailer you can haul and its maximum allowed weight.
Jul 31, 2014 | Toyota Camry Cars & Trucks
Towing capacity for y plate Citroen Picasso 1.6 petrol
Rule of thumb for small cars is maximum 500 LBS. tounge weight (on the trailer hitch ball or receiver) with a total trailer weight not exceeding one half total vehicle weight without fuel.
Jul 30, 2014 | Cars & Trucks
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Freezer is working but refrigerator will not get colder than 50 degrees
Your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Apr 28, 2012 | Westinghouse Top Freezer 18.2 Cubic Foot...
What is the standard fork oil weight and capacity for a kawasaki kmx 125 2000 model?
Total capacity is 615-623cc (1/2 for each Fork leg.)
OEM Fork Oil is type Kayaba 01
This is a 5 weight fork oil
Oct 19, 2011 | 2000 kawasaki KMX 125
I need the size specifications of a x type jag
Maybe this help you:
Length: 4,672mm (15' 4")
Width: (body only) 1789mm (5' 11")
Height: 1,392mm (4' 7")
Luggage capacity: 452 litres (16 cu ft)
Kerb weight: 1,555kg; Gross vehicle weight: 2,035kg; GVW (towing): 2,120kg.
Aug 10, 2010 | 2004 Jaguar X-Type
How much oil do you need to put in a yahama 125cc sr engine
Total oil capacity is 1.6 litres.
When changing oil replace with 1.3 litres
When changing oil filter replace 1.4 litres.
Cheers.
Apr 27, 2010 | 2001 Yamaha SR 125
Dimensions
This model is a 25.6 Cu. Ft.
Height to Top of Hinge: 69 1/4"
Height to Top of Case: 68 3/4"
Case Depth w/o Door: 28"
Case Depth less Door Handle: 32 1/4"
Case Depth w/ Door Handle: 34 7/8"
Depth w/ Fresh Food Door Open 90°: 50 1/16"
Width: 35 3/4"
Width w/ Door Open 90° w/ Door Handle: 42 3/8"
Air Clearances - Each Side: 1/8"
Air Clearances - Top: 1"
Air Clearances - Back: 1"
Approximate Shipping Weight: 360 lbs.
Capacity
Total: 25.6 cu. ft.
Fresh Food: 16.02 cu. ft.
Freezer: 9.59 cu. ft.
Shelf Area: 22.4 sq. ft.
Dec 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
