Question about Samsung HCM4215W 42" Rear Projection Television
HCM4215W Blue projector
I have an issue with my blue projector and now the silicone coolant has leaked out all over the place in addition to the blue convergance being completely out of whack. Do you know the part number for the blue projector so I can order it? Is there something easier to do than replace the whole thing or would that just be the best bet? Plese let me know. I appreciate your advice!
  • Samsung Master
  • 8,617 Answers
Go to the following link and leave them an email with your model number and what the problem is, they should have all what you need plus free support to get your set back up and running. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 28, 2008
How do I fix a blue halo around the picture on my Hitachi CP-SX1350 projector?
Have you tried cleaning the lens on the projector? Dirty optics can cause problems with proper light refraction. Hope this helps.
Jul 03, 2014 | Hitachi CP-SX1350 Multimedia Projector
Blue haze/fog all over screen
As it appears from the images that the images are fine. The sanyo PLV-Z2 is a LCD projector. So basically it projects 3 R G and B lights to make the screen. Yes it is definately not a LAMP issue. Either dust could have accumulated on the R and G panels thus leading to these prominent BLUE patches or if the LCD panels are damaged, u have to get the G or R replaced.. try running a application like Displaymate from "http://www.majorgeeks.com/DisplayMate_d4189.html" and see which of the panels is exactly responsible for the problem. I think this should sort it out.
Dec 26, 2007 | Sanyo PLV-Z2 Multimedia Projector
ALL OF MY MOVIES LOOK ON BLUE COLOR
1.leaking polarised glass parts in the blue channel.
2. worst case a leaking lcd panel, impossible and very expensive to replace, you will need a complete optical block
May 29, 2012 | Eiki LC-SB20 Projector Multimedia...
I have oil in my coolant tank. I was told to replace my Intake manifold gasket. I've also herd about a product called blue devil that fixes these problems without takeing apart the car? has anyone...
If you have oil in the coolant then NO, only if water was going into the oil then yes, but because its oil in coolant a repair of the gasket will be required.blue does work for coolant leakage,
May 08, 2011 | 2003 Chevrolet Malibu
Our temperature gauge goes from a blue light to a flashing red. after putting more coolant in, it seems to correct the issue for a little bit then it happens again. Why is this light going on?
The blue light is only supposed to indicate low engine temperature, reminding you to go easy on the engine until the light goes out.
The flashing is either for low coolant or for overheating, and it sounds like you are having a low coolant problem.
If after you add coolant the lights comes back, you have a coolant leak. The most common place for a leak is the coolant flange on the end of the cylinder head. If you take the engine cover off and look at the area where the transmission meets the engine, you should see either pink coolant puddling or pink crusty residue.
It's also possible to have other leaks from the radiator, heater core, water pump, etc. The nice thing is that with the pink coolant it will leave a trace of pink residue leading to the leak if you take a good look around with a flashlight.
Feb 17, 2011 | 1999 Volkswagen Beetle
Hello, I have a 2001 ford mustang gt. At times when I first start it up some white smoke is coming out of both exhaust pipes. I took it to my mechanic and he said it it probably oil getting in the...
usually:
white smoke is coolant leaking into the combustion chamber
blue-ish smoke is oil in the combustion chamber
black smoke is excessive fuel (running rich)
If it is white smoke, pull the oil dipstick and check to make sure your not getting coolant in your oil.
If thats okay check the compression on each cylinder to make sure your head gasket isn't leaking.
if your car is burning oil, you may need to replace your PCV valve(about $5).
As far as oil additives, try RESTORE
Sep 25, 2010 | 2001 Ford Mustang
Projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Feb 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Blue CRT issues?
Yes the puddle is related to the Blue CRT coolant leaking. You are most likely going to need a new Blue CRT drive circuit board and quite possibly a new Blue CRT if the CRT got too hot from not haveing a sufficent supply of coolant. You can get replacement CRT drives and CRts at the following link.
Jan 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Need blue CRT for HCM4215W. Anybody got one for sale? Please help.
I live in Orlando FL, my HCM4215W tv works great.. but moving and want to sell it... if your local, its $250 for it... iec123@hotmail.com.
Jan 12, 2008 | Samsung HCM4215W 42" Rear Projection...
Red color on screen is warped on my LCD projector TV.
Normally the oily fluid coming from a picture tube, is the coolant from the tube. It's very combustible and have been known to start a fire. You have two problems in this set. A leaking blue picture tube. A convergence circuit that needs repaired. Call a local servicer and see if they will give you an estimate over the phone. It's time to start looking for a new digital set. Good Luck.
Jun 23, 2007 | Hitachi 50UX58B 50" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
