Question about Canon PowerShot A60 Digital Camera
Fuzzy picture when i take a picture it comes out fuzzy, with lines and you can not see what you have taken what can i do about this...
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey cheezyswvgrl,
There is a known problem with the CCD on certain models of canon digital cameras, which if this is the problem Canon has said they will repair or replace the camera. I have provided a link below with instructions on what to do. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 28, 2008
Fuzzy picture
have you taken off the screen and tried to clean the lens as well as the mirrors inside the set?
May 04, 2010 | Sony KP-53XBR200 53" Rear Projection...
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
Describe your Canon A95 Fuzzy line problem on images and display.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot A95 Digital Camera
When taking pictures they are all coming out fuzzy/bleary
have a look at what the focus setting is on ,,,if its on close up's,
thats why there fuzzy, its that or the auto focus is playing up,
Nov 08, 2009 | Cameras
There are gray fuzzy lines across the pictures
Sounds like it could be cracked glass or a dirty lens. if its a cracked lens take it to a repair shop or buy new. if its a dirty lens whew! you saved some money just clean it off good luck please rate,
Rshutterbug
Aug 17, 2009 | Canon PowerShot A75 Digital Camera
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Picture is fuzzy, focus & screen fuzzy even before picture taken
sounds like its a physically damaged screen, if its still under warranty take it back to the store, if not im sorry to it's gonna be a chuck it away and start again job.
Sep 29, 2008 | Cameras
Canon PowerShot A60 Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
