Every time I begin to play cd or tape, push power protect comes up and cd and tape stop
  • angelal812 Oct 06, 2010
    yes it is Sony MHC-7AV
    this was very helpful the problem may well be related to the recent massive earthquake and 1400 aftershocks!!!
  • 10,515 Answers
Kindly mention the make and model of the receiver?
Is it Sony?
Thanks!!
Posted on Oct 06, 2010
  • taran_2005
    taran_2005 Oct 06, 2010
    Thanks for your response!!
    here is no reset button on the unit.
    This message usually means that there is a short in the speaker wiring. When a short is detected, the unit protects the unit by not "pushing" any power to the speakers.
    Can you remove all of the speaker wiring at the back and ensure there are no stray strands of copper wire, then re-insert the speaker wires into the correct holes. Also check all of the wire length to ensure that none of the insulation is damaged. Then power on the system again. If no short is detected, the Push Power Protector error message will disappear.
    If the problem still persists, you need to send the unit for repair.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
How to record a cassete tape
Typically, to record on a cassette tape you must press BOTH "Record and Play" buttons at the same time and the tape recorder will begin to record.
Nov 26, 2014 | Audio Players & Recorders
VCR Stops on me
Hello Ro Power,
This might be due to the tape sensor malfunctioning. You will need a schematic, and multimeter, and a LED power meter to work on this problem. When the tape loads it causes an LED sensor to become blocked and then the sensor tells the control chip that a tape is present and the the controll chip allows the tape to continue playing, if the sensor does not work the signal never gets to the control chips and since other events happend and triggered the control chip the control chip looks at this as an error and the stops the tape , some units even eject the tape.
If you do not have a background in electronics, I would suggest that you take the VCR to a qualified shop and have them repair it.
I hope this helps,
Thank You,
Shuttle83
Oct 17, 2007 | Quasar VHQ940 VHS VCR
Recorded album and first track is cut at beginning everytime
you are going from a record(vinyl) to what before you are doing the ipod? a cd or a tape..when recording the tape..remember theres 30 seconds of plastic leader on those reels..need to forward the tape past that leader to the actual tape before the recording begins..the only other thing is that some recordings that are protected will automatically screw up your recording so as to stop copyright infringement..it may be sending a purposely blank signal for a brief period..and thats encoded into the original recording..
Mar 15, 2014 | Sony Sound Forge Audio Studio 9
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
I have a LG DVD 276. When I play a CD it always starts were I stopped last time. How do I get it to start ast the begining?
push the stop button then remove the cd, power off the player and then power it on again then press the eject button and insert the cd it will now start to the main selection.you can now select the play that what you need to select.
Oct 29, 2011 | LG DV276 Recorder
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
How do I tape to tape
you mean to record?first,you must connect the other unit (if you are using two cassette)by using rca plug or earphone plugs.insert the plugs to audio in or aux(this is the unit that will record).if the other unit doesn't have the output audio,use the earphone out instead.time to record.the recorder must be set to tape/aux,(if you are using a unit with radio setting).then,push the play and record button at the same time.don't forget to put in the blank tape ok.then push play to the unit that you want to be recorded.the square symbol is for stop.the arrows pointing left ,rewind.pointing right, forward.the big arrow pointing right is the play and the button next to it is the record button.
May 14, 2009 | Panasonic RX-D29 Radio/Cassette/CD Boombox
Power Problem? My DS55 red standby light blinks at me and won't turn on.
I agree with your diagnosis. If one channel quit and the unit now ocassionally won't output at all then the amp is going into protect. Have it serviced.
Sep 20, 2007 | Aiwa NSX-DS55 CD Shelf System
Protect?
Overload protection circuit kicked in. Check all your wires (speakers,input,output cables), There is a short somewhere and lets hope it's not In the receiver.
Jul 12, 2007 | Sony STR-DE197 Receiver
 Grubhead
Grubhead
