Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Lost TV picture. Turned set off, will not turn on again. Red LED power indicator is on.
    Problem Solver:
  • 8 Answers
Do you get sound when you turn the tv on with a source. if so then I would suspect the voltage to the inverter board or the inverter board itself.
Posted on Oct 06, 2010
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
Need code for sanyo tv
The codes for your Jumbo Universal Remote to control a Sanyo television are 004, 013, 049, 108, 110, 180, and 209.
  1. Turn on your TV.
  4. Enter the first 3-digit code from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
I hope that helps.
Sep 20, 2009 | Innovage Jumbo Remote Control
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
I need the codes for a symphonic tv
The codes for your Jumbo Universal Remote to control a Symphonic television are 033, 053, 155, 189, and 198.
  1. Turn on your TV.
Aug 10, 2009 | Innovage Jumbo Remote Control
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Power Problem
Most often this problem is caused by convergence ic's. STK392-110. Sometimes cause is vert. i.c. Also, many times it is from bad solder connections on circuit board. In any case, short of unplugging unit to reset, there's not much you can do without help from repairman.By(1)removing rear cover,(2) unscrewing 2 screws holding chassis in and(3) undo all clips and wire ties holding wiring in place. Small board on (R) side is conv. Slide entire chassis towards you. Remove 3 screws from small conv. board.Remove and mark 5 plugs and 4 black jumper plugs to free board. Look at bottom of board for rings around solder joints at pins of main amps.(STK392-110). Resolder or replace amps and reinstall board. Reconnect 4 jumpers and 5 plugs in same order. Power up unit and hit magic focus. This is most common repair.
Mar 06, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
