Question about KitchenAid KAWS850L Top Load Washer
Washer will not wash, spin, or drain. Thought it was the motor, so I went and got a new one. Put it in and same thing. The motor just makes loud HUMMM... Even with the motor disconnected from the transmission and the pump. Someone please throw me a bone.
  • 5,911 Answers
If this a Whirlpool manufactured top loader (such as your KitchenAid), the most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch is about $25 - $35 if you perform the repair yourself. Prices will vary between sites so shop and compare. The first three sites on the list also have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If the model number is correct, the lid switch is listed as item 11 under the "Top and Cabinet" parts listing.
As secondary cause would be a defective main drive motor switch (item 20 under the "Brake, Clutch, Gearcase, Motor and Pump" listing). If the replacement motor you purchased did not include the switch, you may have a bad switch.
In addition, a gearcase (transmission) that has seized up, will also cause no agitation or spin problems. The gearcase is listed as item 9 under the same listing as the motor switch. If you check the lid switch and motor switch, and they check good, you may be looking at a transmission failure. This repair is not difficult and I can provide you with step-by-step guidance, if necessary. I would recommend you check the simple things, first, however. If you need additional assistance, please post back and let me know. I hope you find this information helpful.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Oct 06, 2010
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool cabrio washer f 33 error code
Whirlpool Cabrio strange fix. This thing acted strange, If I went to drain spin it would run trying to work but I could not cancel this function and would have to unplug to reset the machine I had the F 33 fault code, I pulled the drum out and found about $2.00 worth of change. Then I put the washer on it's face and removed the back panel then disconnected the hose to the pump and spun the impeller to make sure no blockage was present. lt was clear so I reassembled the washer and washed one load of clothes and had the same problem occur. Washer would not drain or spin. Went back to work on the washer and in the process of moving it out from the wall I disconnected a 4' hose that I hadn't disconnected the first time that I have running to the drain from the drain hose on the washer, at this point I noticed water coming out of the washer drain hose. To make a long story short my 4' drain hose addition had a ripped up sock plugging the hose. Unbelievably this sock made it through the washer and pump and plugged up the hose. I never thought a sock could make it past the impeller so if your Cabrio is not draining or spinning check the hose past the pump, you may have an easy fix.
May 16, 2013 | Washing Machines
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
KitchenAid KAWS850L Top Load Washer Logo
102 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
