Question about Philips SHP 2500 Consumer Headphones
Low overall volume - Philips SHP 2500 Consumer Headphones
What size machine is the Neptune mah5500b?
Judith: According to eHow.com: "The washer has a volume capacity of 3.34 cubic feet. The overall depth is 28.25 inches, the overall height is 42.5 inches and the overall width is 27 inches.
Read more : http://www.ehow.com/list_7586453_maytag-neptune-5500-specs.html"
May 25, 2015 | Maytag Neptune MAH5500B Front Load Washer
How do i fix my volume
Hi Ashlee, Is it the overall volume or is it an individual Application that has low volume?
The volume control in the menu bar shows the whole system volume but many apps have their own volume controls - and if they are set low then turning up the system volume will have no effect.
Mar 06, 2013 | Dell 15.6" Laptop - Intel Core i3, 6GB...
What is size of this refrigerator
Total Volume 27.3 cu. ft. Fresh Food Volume 17.1 cu. ft. Freezer Volume 10.3 cu. ft. Dimensions Overall Width 35.75 in. Overall Height 70.25 in. Overall Depth 33.63 in.
Feb 21, 2011 | Maytag MSD2756G Side by Side Refrigerator
What are the size specifications
Total Volume: 16.8 cu. ft. Fresh Food Volume : 11.96 cu. ft. freezer volume 4.82 cu. ft
Overall Width: 27.5 in. Overall Height: 66 in. Overall Depth: 31.12 in.
Jan 25, 2011 | Magic Chef CTB1722 Top Freezer...
I am trying to find the dimensions of the refrigertor
Overall Width: 35.75 in. Overall Height: 70.25 in. Overall Depth: 33.63 in.
Total Volume: 27.3 cu. ft. Fresh Food Volume : 17.1 cu. ft. Freezer Volume: 10.3 cu. ft.
HOPE THAT HELPS!
Sep 29, 2010 | Maytag MSD2756G Side by Side Refrigerator
The stereo in my 2008 Silverado has very low
If it has a premium sound system some of them have a small amplifier for the over all system and the rear out put may have lost signal out put power.If it does not have an amplifier then I would replace the head unit(deck)with a brand that you like so you have total control,and no that does not sound right.Hope this helps
Jun 21, 2010 | 2008 Chevrolet Silverado 1500
Low media player volume
Hi there... You can reinstall the sound. First uninstall the driver then reboot then install it...
Mar 09, 2009 | HP Compaq Presario C700T
Aspire 4730Z cd/dvd volume low
I had the same problem on my ACER 5810 - Here is how I fixed it...
Right click the speaker icon in the bottom right -> Select Playback Devices (in Win7)
Highlight the speakers and press Properties
Choose the Levels tab - and max out this slider
Then choose the Enhancements tab and select AND apply the Loudness Eq setting...
This is now as loud as you will get (should see about 20% increase overall)
Word!
Mar 08, 2009 | Computers & Internet
Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Jan 26, 2009 | Tascam DP01 All-In-One Recording Package...
Overall volume when burned to disc is too low
This is a pretty common complaint and not unique to the 2488. The basic idea is that commercial CDs get their superior volume levels through the use of lots of compression which occurs throughout the mixing and mastering process. There are lots of schools of thought on how and when to apply compression during the production of recordings and the only real way to learn is to read up on compression and then to experiment.
Having said that, volume can also be increased by normalizing but many people don't consider that to be a completely legitimate way to increase dynamics and it does require working with wav files on a PC as opposed to the 2488.
I use a combination of external compressors, software applications, and the 2488 onboard compression effects when mixing/mastering (but mostly ouboard compressors). I usually don't burn CDs from the 2488 and choose to instead tweak the final mixes from the 2488 on my PC using various programs which gives me better control over various parameters (such as applying normalization to all tracks at once).
So the short answer is that there a lots of different ways to get there but basically when the dynamic range or your recorded material is large, the main volume of a track is going to sound lower because the parts with the highest levels (peaks) are going to need to fit in the -0 db area in order not to clip. When compression is applied the dynamic range is squashed down so that the peaks are brought more in line with the audio level which makes up the main portion of the track (in the middle of the dynamic range). This then allows the overall levels to be brought up higher without the peaks clipping. This is called downward compression.
Compressors can also be used to bring up the levels of low volume sounds without affecting the middle and higher level audio. This is called upward compression and also compresses the dynamic range in order to raise the volume of lower levels audio. This is called upward compression.
So when compressing and then boosting the main levels, the noise floor can come up with it. That is why gating is also commonly used along with compression and most outboard compressors are gates as well.
Hope this helps.
bd.
Nov 10, 2008 | Tascam 2488 Portastudio Multitrack...
Philips SHP 2500 Consumer Headphones Logo
308 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
