Question about Kenmore 95002 / 95004 Electric Kitchen Range
Don't know the model number. What does F-3 mean when it flashes when I try to turn on the oven temperture
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Posted on Oct 07, 2010
My oven is always flashing PF what does that mean
"PF" stands for Power Failure. There should be a reset procedure in your user's manual. I cannot specify this since you don't give the manufacturer or model number of your oven.
Jun 24, 2015 | Ovens
Ge Model Number JPK27WOW1WW - Flashing F3
Please confirm your model number as I only find a JKP27WW1WW.
Thanks
Dec 05, 2014 | GE Ovens
Where is the oven sensor temperture located
typically a metal probe on the inside of the oven. you may be able to search an appliance part website for you oven model number and see part breakdown diagram.
Mar 28, 2012 | Ovens
Don't know how to change paper size on LED screen
what is the model
but at model **3 **6
you can try this:
1- press key drawer & copy together for more 5 seconds
2- when all lamps flashing press {drawer} till the drawer you want to setup
3- then press {copy} till the {other} lamp flashing - "the last one" see the number on the LED screen
4- change the LED screen number "13" to "20" for LT size
Jun 28, 2011 | Toshiba Office Equipment & Supplies
I can`t find the water filter
Dont know the model right off but the water filter is usually in the top back on inside of fridge usually where the dials for temperture are located
Mar 19, 2011 | Frigidaire FRS26H5AS Side by Side...
Something worng with it. it shows OC on the temperture number ?
Typically the "OC" indicates your compass is out of calibration.
If you check your owners manual it will tell you how to re-calibrate the compass.
Let me know.
Regards,
Apr 25, 2009 | Chevrolet Blazer Cars & Trucks
Model KEDT105V F-2 and F-3 flashing and beeping then turn the oven off? MOlson
Hi
The error code F-2 means that oven temp is too high; you need to :
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Error F-3 means you need to open oven temperature sensor/thermal fuse and replace oven temperature sensor/thermal fuse.
Please revert for any further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 25, 2009 | KitchenAid KESC307 Electric Kitchen Range
Oven Flashing "F2"
hi thanks for the question. F2 means a high temp, and to look at the oven sensor circuit.I would replace the sensor. not too expensive and try . the other solution is the circuit board. so try the sensor. thanks the appliance doc
Sep 29, 2008 | GE Profile JTP18 Electric Single Oven
Oven will not work
I had same problem, My solution was to turn off the breaker switch off (disconnect the power) I kept it off for 1 minute turned it back on and it now flames.
Sep 08, 2007 | Maytag CWG3100A Gas Single Oven
Kenmore 95002 / 95004 Electric Kitchen Range Logo
100 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
