Question about Kenmore Kitchen Ranges
What does F-3 mean when it flashes on my oven. Trying to turn on the oven for use
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F3 in your Kenmore range/oven indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Posted on Oct 07, 2010
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Oven was on and all of a sudden I saw flashes of light coming from oven? turned off oven and now oven randomly turns itself on
Does not sound good,
does it give you a error code at all?
the flashes of light sound like a heating element problem, and as far as it turning on itself thats a control issue, I would leave it unplugged for safety reasons.
I am trying to see if I can find some information online about this particular oven.
Aug 23, 2013 | GE Profile JTP18 Electric Single Oven
We cannot turn the oven on! No instruction manual. The 'A' is flashing on the 'clock'/timer - what does this mean?
This means it is in auto mode. It must be in manual mode for the oven to work. Turn the oven to ON. Some clocks have 2 or 3 buttons. Press the buttons at the same time/try all different combinations. This might take a few minutes, be patient. When the oven indicator lights the clock is in manual mode.
Apr 01, 2011 | Ovens
I have a diplomat double oven no instruction or model no the bottom oven will not turn on and i can not get timer to cancel also an a is flashing on top left hand side of clock can you help ?
Sounds like the flashing 'a' means the timer is in automatic mode. I trust that when you turn the bottom oven to on the oven indicator light does not come on. Turn the bottom oven to ON. Then
have a fiddle with the timer. You have to get it to manuel mode. When it goes on to manuel mode the oven indicator light will come on and the oven will then work.
Feb 05, 2011 | Ovens
F93 error. Oven door is stuck, won't open. Display is flashing door locked and continues beeping. This happened once before and a repairman had me press a few buttons and it reset and fixed the...
Hi
Thanks for using FixYa. F93 code means "Maximum oven door lock time exceeded." Actually it's trying to lock the door but is not aware of the time to stop. Please check the micro switch and lock’s motor. Replace whichever has gone bad. To reset it turn it off for more than 10 minutes and then turn it on.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
F2 flashing on screen of my GE Spectra oven.
Your oven temperature sensor has failed and must be replaced.
May 20, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Oven won't work after cleaning
Molly,
"Auto Clean" means that the control thinks the door is locked. If you can open the door, it's obviously not locked. You can try turning the power off at the breaker. Leave it off for 20 minutes or so. See if this resets the control. If not, the high temps in "auto clean" may have fried one of the monitor switches on the door latch.
Let us know what happens.
SG
Mar 26, 2009 | GE Ovens
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Kitchen Ranges Logo
100 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
