Question about Remington "PG350" 7in1 groomer Hair Trimmer
My Remington PG-360 is all clogged up and I want to take apart the trimmer attachment head and clean it. I don't mind breaking it since it was like 30$ and lasted two years (pretty damn good for this POS), but if there's a way to open up the attachment and clean out the hair, I'd really appreciate some help. Thanks.
Remove the trimmer head with a counter-clockwise quarter-twist then hold it under running warm water to clean from both the open back and the blade ends. Use an old toothbrush to clean the blades. Let dry before using. As mentioned above, its a good idea to oil lightly 1x month.
http://www.remingtonproducts.com/ConsumerService/UseCareManuals.aspx
Posted on Jan 24, 2012
SOURCE: Reg Remington Model PG-250
Send back to manufacture. I have 2 and i had to call remington to order the replacement microsreen. very hard item to find replacent parts for
Posted on Feb 26, 2008
SOURCE: Battery Replacement for Remington PG-300 Beard Trimmer
Hi
The manual will give you info on the battery that is inside the trimmer.If you can get to the battery then buy same TYPE or similar to the original---VOLTAGE/CURRENT RATING/CHARGING etc and size, connection
Hope this helps
Jay
Posted on Nov 17, 2007
SOURCE: blades do not cut on the remington hc8017 trimmer
Try cleaning the blades as they maybe clogged with hair.
Oil them regularly to prevent seizing.
Posted on Jun 19, 2009
  • 12 Answers
SOURCE: Blades pull hair when cutting
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
Posted on Aug 11, 2009
SOURCE: I have lost my charger for the Remington BKT2000
Hey I don't know if you still need a power cord but I have lost the hair trimmer and have a spare cord! If you would like it just message me on ebay - queen_of_belgium_dips is my username. I can sell it to you through this if you have an account. £0.50 +P&P (as it is pretty useless to me!)
Posted on Nov 18, 2010
What is the charger polarity of the remington pg-250 hair trimmer
look on the transformer and it shows what the polarity is there on the power cord transformer
Jan 06, 2016 | Remington Health & Beauty
Charger cable for remmington pg-400
You will find the charger at shaveroutlet.com using the link below
http://shaveroutlet.com/remington-charging-cord-for-pg-250-and-wpg-250.html
Jun 22, 2014 | Remington High Precision PG400 7in1...
Remington mb300 battery replace how
The rechargable nickel-cadmium is hard-wired and not replaceable.
Instructions for removing the battery from the user manual:
1. Make sure your groomer is unplugged from any outlets so you don't risk an electric shock.
2. Remove side panels/grips
3. Remove the 4 housing screws
4. Pull or gently pry the clipper halves apart, exposing the batteries.
5. Remove batteries from the unit.
6. Twist batteries to break wires. Wires may also be cut.
I also own an MB-300. The battery still works good and I loved this trimmer but I need a new cutter blade for mine.
Jan 01, 2013 | Remington MB-300 Beard Trimmer
My Remington is charged but doesn't work.
Most likely, the heads are either damaged or are too clogged up to spin. First, try disassembling the blades and cleaning them out thoroughly. If this is not the problem, you may need to change the heads. Remington suggests changing the heads every 12 months. You will find these for model R-650s at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-sp29-titanium-rotary-replacement-heads-p-383.html
Jul 07, 2010 | Remington R-650s Electric Shaver
Battery changing
I have a Reminigton (PG-250) beard trimmer that is very similar in appearance. I was able to get to the battery by inserting a small screwdriver into the botton (where it plugs in) and twisting the bottom and top halves apart. There are no screws. Once you get it started, just go around the groove and pry it apart.
Nov 08, 2008 | Remington Smooth and Silky WDF-3000...
Feb 23, 2008 | Health & Beauty
Hi
Hope this helps
Jay
Nov 17, 2007 | Remington Titanium Precision PG-300 Beard...
Remington "PG350" 7in1 groomer Hair Trimmer Logo
1,577 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
