Question about Toshiba Satellite X205-SLI1 Notebook
Where is the cmos battery located in the computer??????????
  • 182 Answers
#1
Turn off the laptop and remove the AC adapter. Remove the battery from its compartment on the bottom of the computer. Turn the laptop over and remove the screws holding the DVD drive in place and pull out the DVD drive.
#2
Remove the remaining screws on the bottom of the computer. These screws secure the wireless card cover, the memory card cover and the modem card cover. Then remove all of the plastic covers. Remove the wireless card by sliding it gently out.
#3
Remove the corner screws on the bottom of the laptop securing the bottom housing. Remove the housing by pulling it away from the laptop. Remove any remaining, exposed screws on the bottom of the computer.
#4
Turn the laptop over and remove the thin plastic strip that runs along the border of the keyboard with your fingernails. If your fingernails aren't long enough, a plastic card will work as well.
#5
Remove the two screws on either side of the keyboard securing it to the computer. Remove the keyboard.
#6
Remove all of the exposed screws where the keyboard used to sit. These screws secure the top housing to the computer. Remove the housing, exposing the motherboard.
#7
Locate the CMOS battery. It is a small battery about the size and shape of a coin and should be easily visible on the board. Depending on the model of Toshiba you are working on, the CMOS battery will either be secured with a clip or connected to the board by two small cables. Either way, they are easily removable.
#8
Disconnect the battery by pulling gently away from the cables or by popping the clip out. Your CMOS battery can now be removed
Posted on Oct 06, 2010
  • Toshiba Master
  • 7,733 Answers
Inside the case!
How do I replace a y510 cmos battery
Locate your CMOS battery
Caution: When inside your computer make sure you're aware of ESD and all it's potential dangers.
cmos.jpgOpen the computer case and find the battery on the computermotherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in locating it.
Obtain battery information
Unfortunately, most manufacturers will not list the exact type and model of your CMOS battery; therefore, once you have located the battery, write down all information about the battery (Voltage, chemistry, wiring, and packaging). If possible, remove the battery and take it to the location you plan on purchasing a new battery from. The part number for this battery for most computers is CR2032.
Additional buying information can be found on our battery buying tips page.
Removing the battery
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Users with computers that do not have removable batteries only options to install a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Insert the new battery
Once you have purchased a new battery, remove the old battery (as instructed above) and replace it with the new battery.
Enter CMOS values
Once the battery is replaced turn on the computer and resetting the CMOS values to the defaults. After the values have all been entered make sure to save the settings before exiting. Many CMOS setups allow you to press a key (such as F10) to save values and exit all in one action.
If after following all the above steps you continue to experience the same error when your computer starts or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
Apr 19, 2012 | Lenovo IdeaPad Y510 Notebook
Tip
How to clear an unknown BIOS password.
<span><span>Clear using jumper (recommended)</span><br /> <p><b>Precaution:</b> When inside the computer please be sure you're aware of the potential damage that can be caused by <a href="http://www.computerhope.com/esd.htm">ESD</a>.<br /> <p><img src="jumper.jpg" />On the computer <a href="http://www.computerhope.com/help/mb.htm">motherboard</a> locate the BIOS clear / password <a href="http://www.computerhope.com/help/jumpers.htm">jumper or dipswitch</a> and change its position. This jumper is often labeled CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD, PSWD or PWD as shown in the picture to the right. To change the jumper simply remove it from the two pins its currently on so that it covers the pin that is not covered. For example, in the picture to the right pins 1 and 2 are covered, you'd remove the jumper and put it on pins 2 and 3.<br /> <p>Once this jumper has been changed, turn on the computer and the password should be cleared. Once cleared, turn the computer off and return the jumper or dipswitch to its original position.<br /> <p>The location of the jumpers or dipswitches are dependent on the manufacturer of the computer and motherboard. However, below are some general ideas on where to find it. Remember that most motherboards could have dozens of different jumpers, make sure you're changing the CMOS jumper and not something else. If these general suggestions do not help refer to your motherboard / computer documentation or skip to the next step.<br /> <ol> <li><b>On the edge of the motherboard</b> - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.</li> <li><b>By the CMOS battery</b> - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual <a href="http://www.computerhope.com/jargon/c/cmos.htm">CMOS</a> battery.</li> <li><b>By the processor</b> - Some manufactures will place the jumpers by the processor of the computer.</li> <li><b>Under the keyboard or bottom of laptop</b> - If you are working on a <a href="http://www.computerhope.com/jargon/l/laptop.htm">laptop computer</a> the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.</li> <li><b>Other visible location</b> - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.</li></ol><span>Remove CMOS battery</span><br /> <p><img src="cmos.gif" />Removing the CMOS battery like the one shown in the picture to the right will cause the system to loose all CMOS settings including the password. To do this locate and remove the <a href="http://www.computerhope.com/help/cmos.htm">CMOS battery</a> on the<a href="http://www.computerhope.com/help/mb.htm">motherboard</a> for at least five-minutes. After this has been done put the battery back into the computer and turn it back on.<br /><span>Jump the CMOS solder beads</span><br /> <p>Older computers and especially older laptops don't have jumpers or dipswitches and require the user to jump a pair of solder beads on a circuit board. The identification and location of these solder beads can vary and if not available in computer documentation is only obtainable through the computer manufacturer.<br /> <p>If you've identified the solder beads they can be jumped by placing a flat-head screwdriver over the two beads and leaving it on those beads while turning on the computer. Once the computer has booted turn off the computer and then remove the screwdriver.<br /></span>
on Jan 04, 2011 | Computers & Internet
Can you turn off the password on the motherboard
The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box (Make sure you have your manual handy), LOCATE THE CMOS BATTERY (it is look like a silver Small coin) take out the CMOS battery from the main board ( note: Before taking out the battery make sure that you already touch metal object to remove static electricity) . Then once you take out that the bios password will be reset to blank. Put it back after a few minutes. Same process as what you did when you take it out. Hope this help. Good Luck
Apr 16, 2011 | Dell (E210882) Motherboard
My leptop ibm thinkpad A22P is lock with bios password not opned my leptop
Answer: If you encounter a password prompt at boot or the BIOS / CMOS setup is locked as shown below and you do not know the password you will need to clear the BIOS password using the suggestions listed below.
cmospass.jpg Generic BIOS / CMOS passwords
Try using generic CMOS passwords. A complete listing of these passwords can be found on document CH000451.
Use a BIOS password utility
There are utilities designed to help bypass CMOS passwords. An example of a great utility to decrypt / bypass BIOS passwords is the PC BIOS Security and Maintenance toolkit, which is available by clicking here.
Precaution: When inside the computer please be sure you're aware of the potential damage that can be caused by ESD.
jumper.jpgOn the computer motherboard locate the BIOS clear / password jumper or dipswitch and change its position. This jumper is often labeled CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD, PSWD or PWD as shown in the picture to the right. To change the jumper simply remove it from the two pins its currently on so that it covers the pin that is not covered. For example, in the picture to the right pins 1 and 2 are covered, you'd remove the jumper and put it on pins 2 and 3.
  1. On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
  2. By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual CMOS battery.
  3. By the processor - Some manufactures will place the jumpers by the processor of the computer.
  4. Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
  5. Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.
Remove CMOS battery
cmos.gifRemoving the CMOS battery like the one shown in the picture to the right will cause the system to loose all CMOS settings including the password. To do this locate and remove the CMOS battery on the motherboard for at least five-minutes. After this has been done put the battery back into the computer and turn it back on.
PLEASE ACCEPTT
Nov 17, 2010 | IBM (08K3261) for ThinkPad A20P, A20M,...
How to change cmos battery
cmos.gifOpen the computer case and find the battery on the computer motherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery you will need to refer to your motherboard or computer documentation and/or contact your computer manufacturer for additional assistance in locating it.
Caution: While in the computer make sure you're aware of Electro Static Discharge (ESD), your computer is off, and that you're properly grounding yourself. Especially before removing the battery.
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. Simply use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation and/or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Enter CMOS values
Once the battery is replaced turn on the computer and enter all values back into CMOS or set the values back to the default settings. Additional information about getting the values back to default can be found on document CH000970.
If after following all the above steps you continue to experience the same error when your computer starts and/or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
May 30, 2010 | Toshiba Satellite A60 Notebook
Reset power on password jumper
Motherboard Jumpers:
Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.
Here's an example of a Supermicro PIIISEA motherboard.
piiisea_jump.jpgAs you can see from the picture, we have added two small red arrows. The arrow to the left denotes the location of the "Clear CMOS" jumpers, while the red arrow to the right denotes the location of the CMOS battery.
Here are the procedures if the jumpers are present on the motherboard:
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then user the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Shut down your computer and disconnect the power plug.
  • Now identify where the jumpers are located, then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down!
  • Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.
  • Leave the jumper in place for 20 to 30 seconds and then return it to its default location.
  • Now plug the power cord back in and restart the computer.
  • When the computer begins it's startup (boot) process, tap the DEL, F10 or F1 key, (whichever is appropriate for your computer) to get into the Bios/CMOS setup. If you need more detailed information as to how to get to the Bios/CMOS setup, follow this link. Bios Basics
  • Once into the Bios/CMOS setup, look for a section or area to set the Bios/CMOS to its default settings. This will return the motherboard to either its basic or optimum settings depending upon the motherboard manufacturers settings. You will then need to verify certain settings, such a CPU and memory as well as hard drive type and size recognition. If you need more information regarding these settings, follow either of these links: For an AMI Bios or for an Award Bios.
  • After making any final adjustments, save your settings and restart the computer. The Bios password should be gone and the Bios set to its optimum settings.
If the "Clear CMOS" jumpers are not present or not available:
The procedures for clearing a Bios/CMOS without jumpers is essentially the same as those given above when they are present, it just takes a little more effort.
  • Shut down the computer and disconnect the power plug.
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then use the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.
  • Normally these batteries are held into place with one or more small clips over the face of the battery. Carefully lift the battery out of its socket and set it aside. Note: Some batteries are actually soldered to the motherboard, so take that into consideration and be careful.
  • Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket.
May 28, 2010 | HP Compaq dc5100 Small Form Factor PC...
How to change cmos battery give me some video or pictures or something like that plz
cmos.gifOpen the computer case and find the battery on the computer motherboard,verify that it will be accessible and that it can be removed. Mostcomputers today use a coin cell CMOS battery as shown in the image tothe right.
If you are unable to locateyour CMOS battery you will need to refer to your motherboard orcomputer documentation and/or contact your computer manufacturer for additional assistance in locating it.
Unfortunately,most manufacturers will not list the exact type and model of your CMOSbattery; therefore, once you have located the battery, write down allinformation about the battery (Voltage, chemistry, wiring, andpackaging). If possible, remove the battery and take it to the locationyou plan on purchasing a new battery from.
Ifyou're computer is using a coin cell battery similar to the aboveexample picture. Removing the battery is relatively simple. Simply useyour fingers to grab on the edge of the battery and pull it up and outof the container holding it. Some motherboards have a clip holding thebattery down. If your computer has this clip you may need to use onehad to move the clip up and the other hand to pull the battery out.
Unfortunately,not all CMOS batteries are removable; some manufactures will only allowa replacement battery to be added. If you're not using a coin cellbattery and are not able to determine how to remove it refer to yourmotherboard or computer documentation and/or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Userswith computers that do not have removable batteries only options toinstall a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Enter CMOS values
Oncethe battery is replaced turn on the computer and enter all values backinto CMOS or set the values back to the default settings.
Mar 08, 2010 | IBM ThinkPad R30 2656 Notebook
I let my daughter use my computer for collage and forgot my password and Iam the adminastrator.my computer is a insperon 530.how do I take the computer back to the factory setting
well, try to short/ground your CMOS battery located on the mother board that may help you.
1. open your CPU Case
2. locate where the CMOS battery
3. remove it
4. turn on your PC and immediately short the + and - of that CMOS battery
5. You can now use your PC. Change your password and don't forget it.
Jan 31, 2010 | Computers & Internet
P5RD1-V BOOT PROBLEM
The CMOS, which stands for complementary metal-oxide semiconductor, is the hardware component of a computer that supports the BIOS, or basic input output system. The two terms are often used interchangeably, and the two technologies work together to perform the same basic function. They maintain the low-level settings on a computer, letting the computer know, even before the computer's operating system starts, what kinds of hardware the computer has available, such as hard drives and video display adapters. A special battery located on the computer's motherboard powers the CMOS. To reset the CMOS on a Dell computer, briefly remove and then replace the battery
  1. Turn off the computer. Disconnect all cables and detach all devices, including USB devices, from the computer. Press and hold the computer's power button for 10 seconds after it has been unplugged. This grounds the system board.
  2. Step 2 Remove the computer cover. All Dell systems have a cover panel on the chassis that you can remove so that you can access the system's motherboard and internal components. For some Dell computer lines, such as OptiPlex, the computer cover is held in place by a release latch located on the back of the computer. Pull the latch to release the cover and then slide the over up and away. Other lines, such as Dimension, have large, slotted thumbscrews. Turn the screws counter-clockwise until they disengage from the chassis, the slide the cover off the computer. Dell computers often ship with the computer's user guide in CD form or with the guide pre-loaded on the system's hard drive. You can locate the instructions for removing the cover from your particular system in the user guide.
  3. Step 3 Locate the CMOS battery on the system's motherboard. CMOS batteries range in size from size and thickness from about the size of a nickel to about the size of a quarter. The CMOS battery will generally be labeled CMOS on the motherboard and will be the only battery openly exposed on the motherboard.
  4. Step 4 Remove the CMOS battery by prying it gently up out of its socket. The sockets are specifically designed to allow the battery to be replaced.
  5. Step 5 Wait 30 seconds, and then replace the battery in its socket. This will reset the CMOS. Replace the computer cover to complete the process.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 14, 2009 | ASUS P5RD1-V Motherboard
Where is the location of the Cmos battery for my
You really need a service manual to try & locate the CMOS battery. With laptops the CMOS battery can be different on each model. These are often located on the motherboard below the keyboard, but a service manual should help you.
Nov 01, 2009 | Acer TravelMate 240 Notebook
Toshiba Satellite X205-SLI1 Notebook Logo
457 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
