Question about Refrigerators
Subzer 550 problem
I am having problems with my subzero 550 refrigerator. the freezer seems to be ok but the temp in the refrigerator temp is not cold enough,and the refrigerator door has lost its suction,it used to be tough to open the refrigerator door but since temperature problem door does not shut tight either,had a company out and the condenser was very dirty so cleaned but problem still going on,dont know if we want to sink to much money into fridge due to age,can you guys give me some ideas of what the problems could be.
IF YOUR CONDENSER COILS WERE DIRTY JUST CLEANING TO OUTSIDE OF THE COILS WILL NOT CUT IT YOU WILL NEED TO BLOW AIR THOUGH THE COIL TO GET ALL THE DIRTY OUT OF THEM; USE A SHOP-VAC THAT BLOWS OR A CAN FO COMPRESSED AIR BECAUSE THOSE COILS ARE ABOUT 4 INCHES THICK AND DUST MAY STILL BE TRAPPED. IF YOU STILL HAVE PROBELMS AFTERWARDS CALL A SERVICE COMPANY TO LOOK AT IT UNLESS THE RF IS 22 YRS OR OLDER, SZ RF 650 WHICH IS TODAYS EQUAL RUN ABOUT ABOUT $5500 TO $6200 INSTALLED SO YOU WILL BE BETTER OF FIXING IT THE AVG. COST OF REPAIR IS 225 TO 1500. MASTER APPLIANCE TECH.
Posted on May 29, 2008
My subzero 550 never stops running. everything is working fine, just had freezer compressor side charged. it just seems wrong to be always running??
try to adjust your thermostat normal setting maybe you set it to maximum setting thats why the temp. cannot reach even your comp.running long hours. or maybe your ref . is over loaded try to lessen the load or your door is have leakage of cold air try to fix gasket.
Mar 04, 2011 | Sub-Zero 700TC Bottom Freezer Refrigerator
I have a sub zero (model 550) bottom freezer. Moisture appears to gather at the right side of the freezer then ices up to the point that the drawer can not be opened. I have replaced the drawer seal and...
I had this problem several times and have learned alot. Hopefully some can benefit from my learning and mistakes.
On the inside of the freezer on the right is a drain tube. The defroster cover flows into this little drain. This drain goes into the pan at the bottom of the freezer, and the water evaporates. My subzero 550 had an old drain heater already in there, but obviously not working properly.
First, defrost the freezer completely. I had also poured hot water down this little tube, but this takes too long, and doesn't clear the drain completely. Also, see if you can tolerate turning the freezer temp setting down. I had mine at 1, and it was sufficiently cold. With this simple method, note the weeks /months until it happens again. If you can live with this, you are done.
If not, order a drain heater (contact Clarke Customer at 800-305-0722 and order item number 4202160, Freezer Drain Heater - under $40). I installed this and got some success, and am still counting the weeks after 8 have already passed.
Good luck
May 16, 2010 | Refrigerators
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
Water is not draining down the drain tube in the main compartment of the subzero 550 refrigerator
clean drain line . force hot water down the drain as the get algi and stuff in them . if problem happens again then use a drain heater kit ( subzero ahd one for this model ) this will prevent ice over .. **** hope this will help ..
Dec 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
1991 Subzer 550 refridgerator/freezer needs new fridge relay/over
Check the refrigeration pages...
http://www.supco.com/ProductCatalog2004.htm
May not be an exact replacement, but a proper match should do.
Apr 08, 2009 | Refrigerators
Subzero 550
Call a servicer to determine if a mullion heater is called for.
Aug 02, 2008 | Sub-Zero Bottom Freezer Refrigerator
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Hi...need help...subzero 550
Make sure the condensor is clean, blow some Air though the Condensor to make sure good Air flow towards Compressors. also, you might have a bad defrost timer or Freezer Control... worst case you might have a bad Compressor... hope I can help....
Jan 16, 2008 | Sub-Zero Bottom Freezer Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
