Question about Maytag Dryers
Just had the idler pulley replaced on my Maytag dryer (loud banging noise)but it now has a very high pitched squeal sound (awful)! When I called the repair guy back he implied that the part might need to be used for a while(self lubricating?) but he wasn't sure and then implied if the noise kept up I may need to replace the dryer as it is probably the motor! It is only 1 1/2 years old! Help!
  • lafh7 May 28, 2008
    Thank you. I will check further although I just got off the phone w/ Maytag and they told me 1 year coverage on labor and parts. A bit disheartening. When he replaced the idler pulley there was soot which concerned me and he couldn't really answer the where and why and that is when he launched in on possibly needing a new motor. He indicated with a nrew motor price and his labor I might as well go buy a new dryer. It is only 18 months old so I am not real happy with that suggestion. It is heating but the squealing/whining sound is quite disturbing.
    Maytag dryer Model # MDGT236 AWW purchased from Lowe's 12/06
  • 525 Answers
Most Maytag products have a 2 yr. parts warranty from the factory, so if you need a motor replaced, do it before your warranty expires. Check your warranty certificate for your particular units coverage.
I never heard of a self-lubricating idler pulley and this problem should not cause you to have to replace the dryer.
Note:Maytag produces several different designs and purchase prices of dryers with their name on it, so it would be beneficial to have a model number, so that we can provide more accurate information.
Let us know if we can be of any more assistance
Thank you contacting us at FIXYA.com
Posted on May 28, 2008
  • David Emmel
    David Emmel May 28, 2008
    After researching the model that you provided, this is a Magic Chef design with Maytag's logo on it, Possibly named Performa. This model is considered a "Heavy Duty" model, whereas, a Maytag design is rated "Commercial Duty", and still contains a Maytag logo.
    Disheartening, yes...In my opinion, this is an unethical practice because of the deception involved. I used to sell both designs, side by side, and at significantly different price ranges, but I always informed my customer of the difference in "Duty" ratings.
    You might try to talk to a different customer service rep. I have found that persistance along with the right attitude can produce positive results. Don't take "No" for an answer! You paid good money for a Maytag brand appliance and deserve a little more consideration for this particular issue.
    Good Luck!
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
We have Maytag Neptune dryer that's a front loader, it's about 10 years old, not sure of exact model. We went to run it the other day and hear this high pitched squealing noise. We were assuming it was...
Yes it could most likely be the idler pully mounted in photo as part 38 Click Here=> Maytag MGD6300T Gas Dryer Part 38 is your dryers Idler & Pulley Assembly Part Number Click Here=> 8547174 There is no photo for that link but that is the OEM part number. When the bearings fall out of the pulley this begins a cycle of from bad to the belt (39 in photo) part number Click here=> Belt, Drive 8547168 Should you have more questions please ask, Thanks, Sea Breeze.
Sea Breeze
Dec 06, 2010 | Maytag MGD6300T Gas Dryer
The dryer heats and turns fine, but makes a very loud and high pitch metallic sound, as if it was suffering
it's either your roller
or more than likley it's your idler pulley that your belt is riding on
Aug 23, 2010 | Maytag Dryers
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
Dryer is making an extremely loud squealing noise. Was told I needed to replace the idler pulley. What do I have to take apart on the dryer to do this?
Turn the power off to the dryer (unplug it).
The back of the dryer will have to be removed. Then disconnect the drive assembly and start checking the pulley components. I have included a picture for a Maytag dryer belt routing below. If it is the idler pulley, it will be the pulley shown just below the motor pulley.
If it turns out to not be the idler pulley, it may be one or more of the drum support pulleys around the drum, so check those too. This would also be a good time to check the belt.
Jan 06, 2010 | Maytag MDE9316 Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Loud banging noise while drying
the Idler bearing maybe going. its fairly easy to replace. go here http://www.repairclinic.com/Maytag-Dryer-Parts?s=b4a8c203
the part is cheap and i will show you how to remove the front door and replace the bearing.
May 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
High pitch squeal
IT IS MORE THAN LIKELY A STUCK DRUM ROLLER OR IDLER PULLEY. I HAVE SEEN IN WORST CASE SCENARIOS WHERE IT HAS BEEN THE MOTOR ITSELF WHEN SUBJUCTED TO LOTS OF LINT AND DUST FROM PLUGGED VENTING. I WOULD CHECK THE FIRST TWO AS THEY ARE THE MOST COMMON. DO NOT OIL THEM.
Dec 28, 2008 | Maytag MDE2600 Electric Dryer
Dryers Logo
131 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
