Question about Nikon N65 35mm SLR Camera
N65. has been sitting in case for a few years. Prior to that it had been used a handful of times. It won't do anything when I insert a battery. No noise, LCD screen shows nothing, flash nothing, not a sound. Like there is no battery in it at all. Any suggestions. I have tried 6 different batteries. tHank you
    Brigadier General:
  • 3,006 Answers
Cameras need to be used regularly to stay in working order. If left, the lubricant films inside dry out and gum up.
As your camera is virtually worthless these days a professional repair makes no economic sense. You can try to free up the camera by leaving it in a warm dry place for a few hours and then trying a fresh battery. As the camera is already effectively a write off you may also wish to try slapping the base down fairly hard on a table as you switch it on. The combination of heat-softened lube films, a fresh battery and the physical shock might just be enough to free off the gummed part, but if there's more than a few gummed up parts then this won't work.
N65's/F65's or similar models can be easily obtained on your local FreeCycle/Freegle groups if you're a bit patient and check often. It's where I've got almost every Canon and Nikon model in my (regularly used) collection. Preventing the fault means turning a stored camera on at least once a month and operating everything you can a few times.
Posted on Oct 06, 2010
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
I have a Nikon N65 and put new batteries into the machine. I can't seem to find a thing wrong with it but the screen won't turn on. Any suggestions?
If there's a battery check button, try that to see if you're getting power elsewhere, or see if the functions inside the viewfinder are working. Check to see if the battery contacts are dirty or corroded. If so, use the eraser of a pencil to clean them. If that doesn't help, there's either a dead circuit, or a loose contact and you'll need to contact a repair tech.
You can either contact Nikon directly, find a local reputable shop if you have one in your area, or if you have to go through an online dealer I'd recommend KEH Camera (KEH.com)
Sep 03, 2011 | Nikon N65 35mm SLR Camera
Nikon N65 Won't Turn On , With NEW Batteries . This Camera Is NEW ! Please Help ''/
Nikon hasn't manufactured the N65 is several years now, so if you bought it it was either misrepresented as new, or possible new-old-stock (a never sold/used item, that's been sitting on the shelf for a number of years). I'd be willing to venture you probably ran into a disreputable seller.
Either way, open the battery compartment and look for corrosion in the compartment. If that's present clean it off with the eraser of a pencil and try again. If that doesn't work, contact Nikon service with the warranty information in your package. If it's a new item, it'll still be warrantied since the warranty won't begin until it's sold to a consumer.
If, however you find that the camera was sold 10 years ago and no longer under warranty, you'll probably want to either find a local reputable shop, buy another camera if yours turns out to be too expensive to repair (impossible to tell until someone looks at it to determine the issue), or if you don't have a local shop I'd recommend KEH Camera in Atlanta, GA for mail-order/internet dealers. They've been in business many years and are very reputable.
Aug 23, 2011 | Nikon N65 35mm SLR Camera
My 92 volvo 240 has been sitting outside all summer. i have started it a few times and went to start it today. it won't do anything. what could be the problem and a solution?
"It won't do anything" means that there are no dash lights, no buzzers, nothing?
Any car has very slight electrical drains when it is shut off. For one thing, the clock is running, but there are a number of other tiny loads as well. With a good battery, you should be able to park a car for six months to a year and still start it.
However, if you start the car several times without running it long enough to recharge the battery, or if the drain is larger than it should be due to electrical problems or aftermarket accessories, you can get a failure to start.
Unfortunately, maintanence-free batteries don't tolerate being run completely dead very well, and many owners have unhappily found that draining an older battery once or twice was the last straw that ended their battery's life.
I suggest that you borrow a charger or a set of jumper cables to start the car, and drive it 30 minutes or so to fully charge the battery. If you have more problems, get the battery load tested at a shop that sells batteries to see if it is still OK.
Jul 27, 2011 | 1992 Volvo 240
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
I have a Nikon N65 camera that I have not used in a year or so I put new battery in the camera and it would not come on at all,tried several other batteries and still no go, I am confused so could you...
Cameras are a "use it or lose it" device, especially old ones like your N65.
It's most likely that the internal lubricant films have dried out and gummed up due to lack of use. On older mechanically operated models it's sometimes possible to free things off by leaving the camera in a very warm place for a good few hours and then gently forcing the controls against the softened grease or even by banging the camera against a firm surface. You have almost none of those options on the N65: it's an autofocus model with electronic controls, and the all plastic construction won't stand up to abuse. The only thing you can try is to leave it in a warm place and then try turning it on.
Camera servicing could solve the problem, but your camera is a consumer grade model designed for a five to six year maximum lifespan and was never intended to be serviced. The cost of servicing far exceeds the residual value of your N65 body (just a few dollars).
If you cannot get your camera working then it's time to bid it farewell. The good news is that the worthlessness of many 35mm SLR bodies (and many lenses) makes them easy to obtain for free/cheap. I've had dozens of them over the last few years from friends, neighbours and relatives just by asking and most of them have come from total strangers via my local FreeCycle and Freegle groups. On one day alone last year I picked up a boxed and virtually unused F75 (N75 in USA) with the 28-100mm kit lens and a freshly serviced Nikon N8008 with a Sigma 24mm AF and a Nikkor 300mm. Everything worked perfectly once i replaced the batteries. A week later I collected an Olympus OM1n kit for free and was offered an Olympus Pen FT plus lenses for just £10 (worth well over £200). None of this is intended as a boast, it's just to illustrate that you can get superb and possibly upgrade quality replacements for just the cost of fuel mileage and a set of batteries.
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to replace it with another.
Mar 04, 2011 | Nikon Photography
HOW TO GET STARTED WITH NIKON N65, I DO NOT HAVE A MANUAL. HELP PLEASE.......TNX.
Basically, you insert batteries, load film, attach a lens, point the camera, and press the shutter release button :-)
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 11, 2010 | Nikon N65 35mm SLR Camera
I have a Nikon N65 and I just replaced the batteries. When I turn the camera on, I can't change the shutter speed/aperture or anything (on any setting..manual, auto, etc) and Err flashes.
Camera has a fatal error and should be sent in for service, or replaced. A used on may actually cost less than repairing your old one. Check out KEH.com
Nov 09, 2009 | Nikon N65 35mm SLR Camera
How can I start a small Quartz clock?
The first thing to try would be to test the battery. If the battery is good the problem may be the mechanical works need to be started in motion. If it has swinging parts try to get them swinging. If it has hands set the time on the clock. Hold the the clock in your hand with the face towards you and rotate it clockwise a few times to get the gears moving. Sometimes just letting it sit upright for a day or so will be enough to let the clock start working. I hope this is helpful to you.
Carol.
Apr 12, 2009 | Watches
Nikon N65 35mm SLR Camera Logo
117 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
