Question about Saeco Incanto Classic Espresso Machine
While turning knob to control steam nothing came out but no obstruction found suddenly a BANG then wide spread steam and alas no vapor or coffee did my stem manifold break and WHY? thanks for any help oh by the way this is a refurbished unit which made 12 or so espressos with cap milk without a hitch ; pump sounded but nothing occurred
  • jmbehave Oct 08, 2010
    thank you; i guess the puzzling thing is why? Few have said they receive returns for such or should I buy lottery ticket because this is rare? LOL The good news is the company unhesitatingly is replacing it; how is that for rare service in the 21rst century jm
  • 1,089 Answers
HI
Sorry to say but you have a ruptured tube probably going to the boiler. I would call the company that sold you the machine to repair it.
Posted on Oct 06, 2010
Hi, I have a delonghi 3400 espresso machine. When I turn it on, it says "turn the steam knob". I turned the steam knob to "on" and nothing happens. I pushed all the buttons and...
you must purge the machine first, by waiting till the light turns on then slowly turn steam knob until a steady stream of water appears.Make sure unit is full of water.
Feb 17, 2011 | DeLonghi EAM3400 Espresso Machine
Have "new" reburbished machine suddenly lt it
might be the tube where it sucks the water up to brew in the first place, easiest way without tearing her apart is to brew a pot with CLR(Calcium,Lime Rust Remover), look up the water to CLR ratio and clean well when finished (run a few just waters after) Hopefully you'll be getting your Java fix in no time
Jan 20, 2011 | Saeco Coffee Makers & Espresso Machines
JUST HAD IT SERVICED. RAN TWO SHOTS OF ESPRESSO, STEAMED MY MILK JUST FINE. THEN WHEN I TRIED TO DO ANOTHER SHOT, PUSHED BUTTON AND NOTHING HAPPENED. STEAM LIGHT FLASHING, WON'T GO OFF.
Hi
If you steam and then try to make another coffee, you need to cool the boiler off. Turn the steam off by pushing the steam button again, then open the steam knob and running water until the flashing light turn to green steady. Then make you coffee.
Sep 10, 2010 | Saeco Magic De Luxe Espresso Machine
The two coffee lights and the water light are flashing
Had the same problem. I sealed my lips around the steam wand and sucked as hard as I could, first with open steam knob, then with closed. Obviously there was some air left inside from steaming before. Machine worked fine afterwards.
Nov 30, 2009 | Starbucks Saeco Italia Digital Barista...
Maxkon SK 201A Coffee machine only has one rubber pipe
hi - had same prob= found out modern maxcon machine has only one tube in water tank- other is internal. turn steam knob to off position- anti clock - and wait till water / coffee light is green- then water will come out from filter . when wanting the steam- turn the steam knob clockwise - hope this helps - susan
Jun 27, 2009 | Coffee Makers & Espresso Machines
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Machine will turn on but that is it
The light 20 is power control light, 26 light if any problems are indicated on the machine and should only light if there are any trouble with the machine. 22 should light when the temperature is right.
Try to open the steam knob and make a cup of water.
Apr 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Cafe verona delonghi
You need to turn the knob on top to the steam logo. then turn the knob on the side to open the steam valve. then when you get all the steam you need turn the knob back to brewing
Sep 11, 2007 | DeLonghi Caffe Nabucco BCO70...
Saeco Incanto Classic Espresso Machine Logo
266 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
