Well the problem is not with the monitor.....its just that you got to update the Graphic or display drivers
As you updated the system OS so now you got to install the Graphic drivers and in order to do so..use the the addition disc that you might have got the manufacturer (i.e. Driver & Application CD) or if its a self assembled computer computer then use the Motherboard CD
Else you can go to manufacturer website and download the graphic/display adapter drivers
If you would have mentioned the Model & make of your system, I could have helped with the direct download link
Thanks
Turn on the PC. Press F8 at booting into windows 7. It will display many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
