Question about Kitchen Ranges
Electric range I think I'm a little confused so I will try again. This is trible. I accidentally pushed the clean button on my stove and opened the oven door before I realized it. It is now locked and I cannot get it unlocked. Pushing clear does nothing. It is a fridgedare electric range with a self cleaning oven. The model # is FEF364BWB and the serial # VF50835097. how do I get it to unlock?
    President:
  • 2,712 Answers
Yes, like I said, unplug the range from the wall socket. There should be a circuit breaker that corresponds to that particular socket. Switch that off as well, and wait about 15minutes. After that, please plug the range back into the socket and turn on the circuit breaker. That should reset the device.
If that does not work, you can either try calling the manufacturer, or get a repair guy to come and physically unlock/replace the interlock assembly.
PS, if you have more queries, please reply to this same post, you need not start a new post, or else I may get confused, considering the number of posts I have to handle :) If you reply to this same post, I will have an idea about the issue and you will not have to repeat things for me again :)
Posted on May 28, 2008
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Electric stove works, oven turns on briefly then shuts down
Try turning off the power at the switch again and leave it off for a little while, sometimes the microprocessors become confused and need time to re adjust.
Apr 10, 2014 | Jenn-Air Kitchen Ranges
I accidentally pushed the lock button on my stove and can't get it to unlock.
You should be able to push cancel/off and the door should open. If the oven started the clean cycle it may not open till it has reached a certain low tempature, where the door could be opened without the intense heat of the clean cycle burning you
I hope this has helped you,
Gene
Aug 05, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock engaged with door open
push the clear/off button for about 3-5 seconds this should release the latch
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I did not follow directions on self-cleaning and now stove is loc
Since the door is open and the lock is engaged, you will need to hold the "door closed" switch in located in the top left door opening. Push and hold the switch in, push the clean button, set the time at 3:00 hours, keep holding the switch in for 20 seconds, then push cancel button. The motorized locking mechanism should disengage. Then, you can release the switch. Hope this helps.
Dec 06, 2008 | Frigidaire FEF352 Electric Kitchen Range
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Dec 28, 2007 | Whirlpool RF378 Electric Kitchen Range
Oven beeping, door locked F9 error
Have you tried to unplug the range for 5 minutes? That may reset the programming that is going on.
Nov 18, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
