Question about Lexmark X9575 InkJet Printer
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
  • 187 Answers
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Posted on Oct 06, 2010
SOURCE:
I'm trying to put ink into the ink cartridge, we just bought it today. Whenever I try, theres a pop up that says "printhead failed to move ink cartridge into position" what do i do ?
maybe your ink cartridge is stock. try to pull out the ink then put it back turn off your printer then on if still not solve, just bring it back where you buy you have your warranty for that to replace.
Oct 06, 2010 | Epson Office Equipment & Supplies
I put in a new black ink cartridge now it doesnt want to print says ink cartidge is low, its not then just feed paper all the way through
Find out if you have not bought an expired cartridge.Service the printer and replace the cartridges with good quality cartridge.
Jun 02, 2010 | HP DeskJet 9800 InkJet Printer
Inks won't work.
You have probably purchased refilled cartridges, try to replace with genuine ink cartridges will solve out your problem.
Apr 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
The window says that the wrong ink cartridge is installed and when I remove it and replace it it says remove and replace cartridge. I have put 2 new cartridges in and they are the right ones. It will not...
sometimes when replacing ink cartridges some idiot that filled them to begin with doesnt reset the calibration they just shove the ink in and box em up!!
its not your printer its who you bought the ink from
Jan 14, 2010 | HP PSC 950 All-In-One InkJet Printer
Why is my ink still say no ink?
cartridge may be defective.
take the cartridge out and put it back in to your printer.
turn the printer on and off.
if the cartridge is still not recognized by your printer, call epson, i believe they will replace the defective cartridge.
May 21, 2009 | Epson Stylus C84 InkJet Printer
I have a new canon mp210 printer ink is low i bought new ink to replace old their is no ink cartridges in printer. When i look at the pictures to load new ink and put it in alarm light is flashing
Even if the ink level is low, you can continue printing.Press the paperfeed knob for 5 seconds. inklevel indicator will stop now.
Sometimes a new (or refilled) cartridge is not recognised correctly.
When one color is really mt, stop printing and replace inmideatly the colorcartridge.Printing or scanning without the 2 cartridges in place is impossible.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
I bought two new ink cartridges. i can't get them to work.
Replace the cartridges. Sometimes the NEW printer cartridges doesn't work. If you go to the store they will replace them.
Another tip is:
Put boiling water in a cup
Put the end printer cartridge (ink) close to the water to receive the steam during a couple of minutes. (Do not put into the water)
Put it back into the printer and try again.
Oct 07, 2008 | Lexmark Office Equipment & Supplies
Replace ink cartridge
Took printer back- power up and take all carts out in sequence that would not register, then put them back in sequence- works fine now! At one time you could not do this with Epsons but it seems you can do so now. Printer happy- me happy- £50 worse off as bought another set of ink carts so I won't get caught out again with no ink. However given one black cart for my trouble so happy again.
Sep 16, 2008 | Epson CX8400 All-In-One InkJet Printer
Replac ink
i got something like that too .. it was my yellow ink which was doing it ... at a point i was so fed up that i put another blue cartridge and you know what .. it works ... so it means that the brand new yellow that i bought before was not even good !!! WOW .. way to go Brother !
Jul 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
New ink went bad overnight
DancerTiffy,
I can't tell you why your machine is acting like that nor can I tell you that you have a problem.
What I can tell you is that you're not alone when it comes to the ink drying out all of the sudden. In the past few years I can't count the number of people who have explained this problem. I also can't count the number of people that have said their Epson produces the highest quality prints and their happy with it.
Your problem could be the printer or it could be the ink. Since it already happened twice it's hard to say.
  • How long have you had the machine?
  • Still under the retail store's return policy?
  • Still under the manufactures warranty?
  • Only two prints were printed?
May 30, 2008 | Epson Stylus RX580 InkJet Photo Printer
Lexmark X9575 InkJet Printer Logo
139 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
