Question about Coleman Heating & Cooling
I have a Coleman 5T 13 Seer Heat Pump. When the unit is running there is a lot of vibration (outside unit) and I hear a tinny sound (possibly like the fan hitting something). This seems to be worse during the hottest part of the day. When the unit had its last service they said it was low on freon and recharged it and it seems to be since then that the problem has occurred. Is it possible that the unit is overcharged? And if so is this dangerous, i.e. could it cause permanent damage or imminent failure? Or could it be the balance of the fan also causing unit vibration?
I have a coleman mach roof air on the RV. It keeps blowing the 3amp fuse. Why??
Posted on May 30, 2008
  • 828 Answers
First thing I would ask is did they locate the leak in the system before they recharged it? Your answer is YES to all three of your questions. If the unit is overcharged you can get what is called a liquid flood back to the compressor and this condition can cause compressor failure. Fans are balanced at the factory when manufactured. If a blade is bent or damaged it will throw it out of balance.
Posted on May 29, 2008
  • James Helmer
    James Helmer Jun 03, 2008
    To the second poster: The 3 amp fuse is more than likely for the control circuit only. If it blows there is a problem in the control circuit. Could possibly be caused by a burnt or shorted coil in one of the relays. If a coil is burnt you will be able to tell which one it is by simply smelling it.
WHATS WRONG WHEN THE GAS DOES NOT COME OUT TO BE IGNITED IN A COLEMAN HEAT AND AIR UNIT.
There are several issues that may cause this. I would have you check that you are getting 24 volts to the gas valve when you call for heating.
Things that may cause you not to have 24 volts:
1. Does the draft inducer motor start when you call for heating?
2. Does the pressure switch close after the draft motor starts?
3. Do you get 24 volts after the pressure switch closes.
4. Are all the limit switches closed? There should be 3 of them one in front of the burners (usually with a manual reset button called a rollout switch), one behind the burners (auto reset) and one in the blower section (auto reset)
Do you have gas to the unit"
Jan 11, 2016 | Coleman 2.5 Ton 13 SEER Complete Split...
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
I have a 10 SEER heat pump about 16 years old, yesterday I notice that the outside unit was making a loud click noise in the heating mode. It's very close to the defrost electrical curcuit board. The unit...
Depending on make and model sounds like a check valve clicking. It can sound like it is coming from that area. You say your unit is 16 years old. Honeywell did servey on unit 10 years and older and found out they loose 25% effeicency after 10 years. You may think about changing it out. With the new tax credits you can get a 16 seer unit for the price of a 13 seer. I went from a 10 to 15 seer and my power bill dropped 40%. Rus.
Dec 03, 2009 | Heating & Cooling
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
We installed a 4 ton downflow coleman air handler with evap coil Model number 1854s2m we did not change out the outside unit. the outside unit is a 13 year old 3 1/2 ton intertherm condenser the system is...
you have a missmatched system, for it to work try removing the orfice on the high side txv it is not allowing the evaperator coil to fill with refrigerant properly coleman and intertherm dont like each other since they control a large market in the manufactured housing heating and cooling units electricaly connecting the componets together no issue prefromance sometimes is the issue hope this helps
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
79 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
