Behind the glove box. Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck, please get back to me.
See instructions from autozone.com below.
REMOVAL & INSTALLATION
With Air Conditioning
See Figures 1, 2 and 3
- Disconnect the negative battery cable.
- Remove the glove compartment door and glove compartment.
- Disconnect the blower motor wires from the blower motor resistor.
Fig. Fig. 1: Disconnect the blower motor wires from the blower motor resistor-1988 Escort
- Loosen the instrument panel at the lower right-hand side prior to removing the motor through the glove compartment opening.
- Remove the blower motor and mounting plate from the evaporator case.
- Rotate the motor until the mounting plate flat clears the edge of the glove compartment opening and remove the motor.
- Remove the hub clamp spring from the blower wheel hub. Then remove the blower wheel from the motor shaft.
Fig. Fig. 2: Unbolt the mounting plate from the case
Fig. Fig. 3: The motor can now be removed from the case
To install:
- If removed, assemble the blower wheel to the motor shaft and install the hub clamp.
- Install the motor and blower wheel assembly.
- Secure the instrument panel at the lower right-hand side.
- Connect the blower motor wires at the blower motor resistor.
- Install the glove compartment door and the glove compartment.
- Connect the negative battery cable.
- Check the system for proper operation.
Without Air Conditioning
- Remove the air inlet duct assembly.
- Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
- Remove the blower motor flange attaching screws located inside the blower housing.
- Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
- Connect the wires to the blower motor and position the motor in the blower housing.
- Install the blower motor attaching screws.
- Position the blower wheel on the motor shaft and install the hub clamp spring.
- Install the air inlet duct assembly and the right ventilator assembly.
- Connect negative battery cable.
