Try unplugging it and leaving it unplugged for about an hour. While it is unplugged press the start button two or three times to clear circuit. See what happens when you plug it back in. It is surprising how many small appliance problems can be cured with this simple trick!Try unplugging it and leaving it unplugged for about an hour. While it is unplugged press the start button two or three times to clear circuit. See what happens when you plug it back in. It is surprising how many small appliance problems can be cured with this simple trick!
You can't post conmments that contain an email address.
contact emerson @ 1-800-909-1240 option 3 is microwave. Make sure you have model number and serial number. We are having the arcing problem and burning smell. They will pick up check and replace.
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
